Best hp per $$ items for an 8 second build #3049290
06/10/22 06:37 AM
06/10/22 06:37 AM
gregsdart Offline OP
After having gone down the wrong road more than a few times over the years, i thought it would be good to get opinions on where to put the money to build an 8 second door car? Lets hear it,,,!
Re: Best hp per $$ items for an 8 second build [Re: gregsdart] #3049293
06/10/22 06:46 AM
06/10/22 06:46 AM
Well, i will start, cubic inchs. Buy all you can. Aluminum 4.5 bore block.
Light weight race disc brakes, due to weight savings
Lithium battery and leave it up front. ( 16.5 lbs, save at least 8 to 10 lbs on cables to back of car)
Chrome moly cage, mustang II front, ladderbars
Re: Best hp per $$ items for an 8 second build [Re: gregsdart] #3049298
06/10/22 07:06 AM
06/10/22 07:06 AM
According to one wallace calculater, it takes 3.6 hp per lb or less to achieve a hi 8 second run, for referance
Re: Best hp per $$ items for an 8 second build [Re: gregsdart] #3049299
06/10/22 07:09 AM
06/10/22 07:09 AM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
Light car, big tyre chassis. Total opposite to what I've done grin
Re: Best hp per $$ items for an 8 second build [Re: Tig] #3049303
06/10/22 07:42 AM
06/10/22 07:42 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
We already know. We just don't do it. Don't start with a factory car. Use a light 4 link, strut, tube chassis, panel car. A big engine with high compression. My original short block with similar -1 heads went 8.10@169, 2470lbs 10 years ago before I got it.
Doug
Re: Best hp per $$ items for an 8 second build [Re: Tig] #3049305
06/10/22 07:48 AM
06/10/22 07:48 AM
UK
rb446 Offline
rb446  Offline
UK
Your 655 in my not so light 3300lb '69 Cuda would've gone 8.50>60's@155 if the 2x3 chassis would've handled it. up
As for parts we have a '69 Cuda going 8.70's@154 with an all ally 540 low deck motor on alky with rons toilet, -1's and an .800-ish roller.
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: Best hp per $$ items for an 8 second build [Re: dvw] #3049313
06/10/22 08:30 AM
06/10/22 08:30 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Doug
Doug...what kind of chassis/car was this?
Re: Best hp per $$ items for an 8 second build [Re: racerx] #3049322
06/10/22 09:14 AM
06/10/22 09:14 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
The boosted guys tend to go a different route....ebay turbo & a junkyard LS seems to be all they need.
Re: Best hp per $$ items for an 8 second build [Re: racerx] #3049327
06/10/22 09:36 AM
06/10/22 09:36 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Member here TS3303. Tube chassis latter model Daytona.
Doug
Re: Best hp per $$ items for an 8 second build [Re: rb446] #3049348
06/10/22 10:44 AM
06/10/22 10:44 AM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
Still hopeful that we will dip into the 8's in good air with the 655, needs an honest 1100hp though. wink
Re: Best hp per $$ items for an 8 second build [Re: Tig] #3049377
06/10/22 11:54 AM
06/10/22 11:54 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Nitrous
Re: Best hp per $$ items for an 8 second build [Re: Tig] #3049378
06/10/22 11:57 AM
06/10/22 11:57 AM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Remove weight.
From what you have or by trading up to a lighter car.
Re: Best hp per $$ items for an 8 second build [Re: CMcAllister] #3049386
06/10/22 12:17 PM
06/10/22 12:17 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
No doubt lighter is better period! Cheaper to loose weight than build power. There is no "magic bullet" but having a goal and a plan and STICKING to it will usually yield the desired result. Also having the "want to" is a large part of it, as long as the goals are REALISTIC!
Having said all that been a LONG time since I have NOT had an 8 second car. My 64 has been in the 8's at 3600. I would imagine it makes less power than many here think. It is still a work in progress as well. I just cut the old age out and put a new moly one in it, still have some ignition issue to find and that will likely lead to a complete rewire if the car. My current goal is to run an 8 here in Vegas. We have been 9.teens so far here and one hero run a tad quicker. I just plan to refine whats already done, converter is a tad tight, shocks are just ok and until I can get the chassis to work with all the power in at the hit Ill likely not make my goal. But I know its achievable and realistic. We are also hoping with a few minor changes to the dragsters engine to be in the 6's with a BB Mopar NA...My truck I am building for .90 stuff so ultimately the ET goal does not matter as setting a car up for max MPH on the stop is not the way to go the quickest ET's but hopefully it can go 5.0's in the 1/8 in great air.
Re: Best hp per $$ items for an 8 second build [Re: CMcAllister] #3049394
06/10/22 12:40 PM
06/10/22 12:40 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
tube chassis lebaron 540 .750 roller 1150 dom 2450lbs 8.85 155
used race car $10,000-20,000 engine 10,000 = $30.000 ?
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Best hp per $$ items for an 8 second build [Re: gregsdart] #3049408
06/10/22 01:17 PM
06/10/22 01:17 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Nitrous
Re: Best hp per $$ items for an 8 second build [Re: mgoblue9798] #3049418
06/10/22 02:14 PM
06/10/22 02:14 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
The cheapest power you can get right now is probably a stock bottom end LS, Gen III Hemi, or Coyote ford with a turbo charger on it. Its insane how fast some low budge builds have gone. One of our own members has stepped over to the darkside and gas a 8 second turbo LS mustang, I just can't remember his screen name lol.
The sloppy mechanics 8 seconds for $8000 build was interesting also. Started with nothing but knowledge and went 8.83 for 8000ish. Link https://sites.google.com/site/sloppywiki/sloppy-builds/8s-for-8-mustang
68 Barracuda Formula S 340
Re: Best hp per $$ items for an 8 second build [Re: Bad340fish] #3049424
06/10/22 02:32 PM
06/10/22 02:32 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Hey Greg! wave If/When I get my junk truck in the 8's, then I will chime on on this tread! whistling
Re: Best hp per $$ items for an 8 second build [Re: Bad340fish] #3049429
06/10/22 02:52 PM
06/10/22 02:52 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
We should Just start calling this website “anything goes” or “whatever it takes”. Man Mopar guys are a different breed now.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Best hp per $$ items for an 8 second build [Re: Bad340fish] #3049440
06/10/22 03:41 PM
06/10/22 03:41 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I love watching his builds. The white Colorado was awesome! Slammed together used bits with a China turbo and doing 1,000 HP at the rear wheels. He has a Fairmont waiting in the wings that should be interesting.
'63 Dodge 330
11.19 @ 121 mph
Re: Best hp per $$ items for an 8 second build [Re: pittsburghracer] #3049441
06/10/22 03:50 PM
06/10/22 03:50 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I accept all fast cars, the ones I own happen to be Mopars but I will pay attention and learn from all of it.
If my whole setup were to burn to the ground I would probably come back with a Fox body mustang with a Gen III hemi lol.
