Re: E85
[Re: cesar perez]
#3049046
06/09/22 02:02 AM
06/09/22 02:02 AM
Posts: 43,218 Bend,OR USA
Cab_Burge
How to run e85 fuel reliability ??
Re: E85
[Re: birdtracker]
#3049064
06/09/22 07:59 AM
06/09/22 07:59 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
Do you test every "batch" of fuel to make sure it's 85%? I've heard it can vary and needs to be "adjusted" somewhat.
Re: E85
[Re: second 70]
#3049084
06/09/22 09:58 AM
06/09/22 09:58 AM
birdtracker
Re: E85
[Re: birdtracker]
#3049088
06/09/22 10:14 AM
06/09/22 10:14 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
We only have one chain around here that has E85 and what they really have is E70 year round, but at least it is consistent. I haven't tried it yet, I setup everything for it I just haven't made the move.
68 Barracuda Formula S 340
Re: E85
[Re: Bad340fish]
#3049090
06/09/22 10:17 AM
06/09/22 10:17 AM
an8sec70cuda
E85 was available at a lot of places here for a while, but not as much anymore. If I ever make the jump to a blower, I'll switch to E85.
Re: E85
[Re: fourgearsavoy]
#3049105
06/09/22 12:09 PM
06/09/22 12:09 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Do you really need to change over to the green E85 metering blocks? I have Quickfuel metering blocks on my carb now and I was wondering if I could just modify them or should I just spend the $200 on the QF E85 kit Gus The E 85 metering blocks are different and do make a difference. I have a 4150 based 1050 that was set up for E 85 by an up and comer that used gas metering blocks and it was dangerously lean. We pulled to 4000 and shut it off , went up ten jets and got the same result. Switched to a fresh Quick Fuel 850 and it corrected the lean condition , but was now under carbureted. Up here in Mn. , they use a winter blend that is about E-55 until May , then dump E 85 on top of what ever is in the tank , and by mid June , it is consistent 85%.
Re: E85
[Re: tubtar]
#3049255
06/09/22 10:17 PM
06/09/22 10:17 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Thanks I have the Pro-Form 1050 annular body now with Quick Fuel blocks, bowls, and baseplate. It runs very well right now so that's why I hesitate to change the blocks but I guess I will have to completely change my tune anyway with the new fuel. Maybe when I bolt the new blocks on my A/F ratio will be dead on Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: E85
[Re: birdtracker]
#3049353
06/10/22 11:05 AM
06/10/22 11:05 AM
fourgearsavoy
Rittman Ohio
Looks like I'm going to need a new fuel pump and regulator that is safe for methanol too. Now the tally is approaching over the $600 mark is it worth it for a street/strip car I drive less than a 1,000 miles a year. Gus
Re: E85
[Re: an8sec70cuda]
#3049355
06/10/22 11:09 AM
06/10/22 11:09 AM
Posts: 4,684 Wichita
GY3
Wichita
Do you test every "batch" of fuel to make sure it's 85%? I've heard it can vary and needs to be "adjusted" somewhat. One reason why I decided against it. Ain't nobody got time for dat!
Re: E85
[Re: fourgearsavoy]
#3049359
06/10/22 11:15 AM
06/10/22 11:15 AM
Posts: 20,184 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Looks like I'm going to need a new fuel pump and regulator that is safe for methanol too. Now the tally is approaching over the $600 mark is it worth it for a street/strip car I drive less than a 1,000 miles a year. Gus Some guys over-think this. When I plumbed my car years ago I used number 10 black cloth line in it and number 8 to the carb. I did this back when I was running 9.80’s on BP pump gas and W2 heads. I switched over to alcohol years ago and run the same BG400 pump and regulator. I have rebuilt the pump a time or two but you expect that on a pump that is over 15 years old. Larry smith gave me a used one several years ago so I rebuilt it and now carry a spare. Regulator has never been touched
Re: E85
[Re: pittsburghracer]
#3049370
06/10/22 11:33 AM
06/10/22 11:33 AM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
EFI makes this much easier.
I would personally only run drum E85 if carbureted rather than chase the alcohol content.
Re: E85
[Re: INTMD8]
#3049434
06/10/22 03:21 PM
06/10/22 03:21 PM
Posts: 2,512 PA
moparacer
PA
I run it on my Barracuda. Its nothing special, small block low 11s. I buy it at the local Sheetz store and in the beginning I was testing it all the time, but I quit because once the summer blend hit the tanks it was consistent. Not so much of a deal like it used to be though. Last I bought was $2.39 and now its $4.00. Still cheap 105 octane fuel though.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
