Preferred brake line vendor?
#3049004
06/08/22 09:00 PM
06/08/22 09:00 PM
Posts: 2,059 NW/Indiana - Chi town
ricomondo
Seems to be a plethora of brake line vendors; Fine Lines - Right Stuff - InLine tube -
Is there one vendor with a better product than most? I'll be replacing front/rear brake lines, fuel and the emission line on 71' Demon.
GY3 71 Demon 340
Re: Preferred brake line vendor?
[Re: ricomondo]
#3049015
06/08/22 09:34 PM
06/08/22 09:34 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I've used all 3 over the decades, and I would go to them in the order that you listed them, with Fine lines being your best choice.....
[Re: ricomondo]
#3049191
06/09/22 06:38 PM
06/09/22 06:38 PM
Posts: 1,385 Az
69hemibeep
Az
Inline tube
1969 Hemi Roadrunner 2nd owner
[Re: belv2vert66]
#3052184
06/21/22 01:46 PM
06/21/22 01:46 PM
Posts: 1,378 Back In Iowa
belv2vert66
Back In Iowa
I have had issues with all of them. The latest with Inline:
1) Received someone else's order. I ordered a 7 piece brake line kit and a return fuel line. I got some transmission lines 2) Got the re order. Brake lines were sent. Got the wrong return fuel line. 3) Received the correct return fuel line. Tried to install the front to rear brake line. Took off the rubber cap and had this flare (pic below) Waiting for the replacement.
Well here is number 4. Received another front to rear return fuel line. Not even stainless........ Another try for the brake line is on the way now.
[Re: belv2vert66]
#3118013
01/31/23 10:38 PM
01/31/23 10:38 PM
Posts: 102 eastern L.I. ,NYC
kingdragon
eastern L.I. ,NYC
Inline tube fuel line set for my 71 R/T is not even close. 3' short on the return line and all three have bends that are off by 6". All three lines are intended from the factory to run parallel to their destination, not the inline tube set. Worst part is their short so I can't even alter two out of the three. No gravel guard like factory set either. I should've bent them all myself like I've always done.
I only buy MADE IN USA.
