Re: blow by out breather..
[Re: 8urvette]
#3048752
06/07/22 10:01 PM
06/07/22 10:01 PM
Posts: 43,292 Bend,OR USA
Cab_Burge
How wide did you open the top and 2nd rings too? Are these new rings or the old, broken in original to this build rings Sounds like you may have twisted a oil ring and spacer up when installing the pistons ![work work](/ubbthreads/images/graemlins/custom/work.gif) I've never done that ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) I would do a leak down test on the motor when cold and hot, rock the crank back and forth a little bit at TDC also ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
[Re: rebel]
#3048853
06/08/22 11:15 AM
06/08/22 11:15 AM
Posts: 11,692 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Leak it.
Vac-u-pan will help to a point, if you have open headers. Mufflers and/or exhaust system reduces the effectiveness considerably.
[Re: 8urvette]
#3049034
06/08/22 11:41 PM
06/08/22 11:41 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
If it's a 4.3750 bore .026-.028 is what I come up with which isn't horrible. What did you gap them to?
What kind of ring is it? Not sure you can get away with spraying that much without a stainless (Mahle GNS) or ductile iron (Hellfire) top ring.
[Re: rickraw]
#3049909
06/12/22 12:37 PM
06/12/22 12:37 PM
Posts: 4,696 On the parachute mount
n20mstr
On my sons small block , we gapped the rings .030 . He welded bungs on his valve covers and ran -10 to the headers . Put a separate -10 to a catch can with a check valve . At idle it pulls just off of 0 on a vac gauge . On the track at the stripe it has 5 inches pan vac
....BAD A$$ STREET CAR.....
[Re: 8urvette]
#3049912
06/12/22 12:41 PM
06/12/22 12:41 PM
Posts: 257 Alberta
440_Offroader
Alberta
Might have a top or second ring stuck or not sealing. A small mark on the piston by the ring, or small piece of dirt in the ring land, could hold a ring up. The oil ring can be doing its job, by keeping oil out of the combustion chamber. It doesn't do much for keeping combustion out of the crankcase with its low tension. It's a lot of work to check, but if it wasn't like that before, then something isn't quite right. Aside from that, and to be more relative to your question.... Similar to a PCV system with a catch can, I've seen industrial engines have special canister with an element inside. They run in after the air filter (or intake manifold like a PCV), to draw the crankcase pressure down. The coalescing element catches the oil vapor, and the catch can has a small line for oil to drain back down to the oil pan. They have relatively large lines, so tend to draw too much vacuum in some instances. A flow control valve is then installed, to keep crankcase pressure at -1"H2O. Just an idea for you, but may be too much, for under the hood of your car.
