Holley carb fuel leak?
#3048251
06/06/22 11:33 AM
06/06/22 11:33 AM
Posts: 2,094 New Mexico
JMCFAN
New Mexico
Holley carb restored by Scott for my 70 RR.. Very few miles on it since done although the carb sat for a few years after it was completed because my paint guy took FOREVER!! See pic....leak is at the fuel line fitting. What is the washer etc that I need to replace or...???
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
Re: Holley carb fuel leak?
[Re: JMCFAN]
#3048259
06/06/22 12:12 PM
06/06/22 12:12 PM
Posts: 19,529 north of coder
moparx
look very close at the area where the casting line is. i have seen where there is an almost impossible to see crack starting there at the end. of course just replacing the gasket may be all that's needed.
[Re: moparx]
#3048265
06/06/22 12:36 PM
06/06/22 12:36 PM
Posts: 25,902 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Or simply tightening the fitting in the bowl.
[Re: John_Kunkel]
#3048266
06/06/22 12:37 PM
06/06/22 12:37 PM
JMCFAN
New Mexico
Or simply tightening the fitting in the bowl. Tried that.....first thing
[Re: moparx]
#3048277
06/06/22 12:55 PM
06/06/22 12:55 PM
JMCFAN
New Mexico
look very close at the area where the casting line is. i have seen where there is an almost impossible to see crack starting there at the end. of course just replacing the gasket may be all that's needed. Copper washer correct? Anyone know size etc..? Or just take assembly to Napa....
[Re: moparx]
#3048697
06/07/22 06:42 PM
06/07/22 06:42 PM
Posts: 4,278 Morrow, OH
markz528
Morrow, OH
look very close at the area where the casting line is. i have seen where there is an almost impossible to see crack Yup. Had one like that and it drove me crazy. Finally found the crack.
[Re: markz528]
#3048846
06/08/22 10:58 AM
06/08/22 10:58 AM
Posts: 15,459 Omaha Ne
TJP
Omaha Ne
look very close at the area where the casting line is. i have seen where there is an almost impossible to see crack Yup. Had one like that and it drove me crazy. Finally found the crack. If a crack is suspected, one could use a very thin layer of paint or machinist's dye (dykem) over the suspected area. the fuel will "rinse" the color away exposing the source. A sharpie may work as well. To verify, mark a piece of metal with the sharpie, let it dry for 5 minutes or so, then see if a bit of fuel dissolves it
[Re: 4406bbl]
#3048852
06/08/22 11:13 AM
06/08/22 11:13 AM
JMCFAN
New Mexico
Whatever you do don't not keep tightening it without a new gasket, tighten it and then hold it while tightening the fuel line. If you back it off and retighten the seal is done. Quick fuel/holley makes a nylon one that works well in most cases also.26-102 holley. 26-102 holley found these at local speed shop. Will post results...
[Re: JMCFAN]
#3048917
06/08/22 02:40 PM
06/08/22 02:40 PM
JMCFAN
New Mexico
Well appears the leak is at the fuel line itself... will verify tonight when I can get a 2nd set of eyes.
Any recommendations on best place to purchase a new one that would ship sooner then later..... YO is horrible....
Never mind. Found one on Ebay from Inline Tube....
[Re: JMCFAN]
#3048928
06/08/22 03:40 PM
06/08/22 03:40 PM
Posts: 20,843 A collage of whims
topside
A collage of whims
Sometimes, the flare on the tube is garfed, which either precludes tightening, or for bonus points, also garfs the fitting. Check your fitting, and mock up the new line. Sometimes the angle is off, and needs a tweak to properly seat. On the AVS lines, the one I got from Classic (maybe also an Inline product, I don't recall for certain) also had incorrect bends over the valve-cover area.
[Re: moparx]
#3049413
06/10/22 01:37 PM
06/10/22 01:37 PM
JMCFAN
New Mexico
It was the flare fitting. Odd that it didn't leak till now.... reseated it a few times... ended up removing the carb seal fitting and lining up and snugging it...then installed as one piece. no leaks.
