727 BAND #3047316
06/02/22 09:39 AM
06/02/22 09:39 AM
westerly, ri. usa
440lebaron Offline OP
westerly, ri. usa
hi,
727 kickdown band, have both flex and solid cast, (red no Kevlar) 5.0 lever and steel billet drum, race only, using 2 step, any preference??
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: 727 BAND [Re: 440lebaron] #3047320
06/02/22 10:04 AM
06/02/22 10:04 AM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Flex reacts faster...additionally I 'd use a 3.8 lever...but that may be trans brake logic,
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: 727 BAND [Re: 440lebaron] #3047322
06/02/22 10:04 AM
06/02/22 10:04 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I personally would use the solid band (red lining), and a 3.8 lever if you can get one. However, I successfully used a 5.0 lever for years, without issues. Good luck with it!
Re: 727 BAND [Re: Leigh] #3047356
06/02/22 12:14 PM
06/02/22 12:14 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Most of the stuff I fool with are 904s. They get a wide flex band and a 4.2.
I have 5.0s. I keep them in the box with my pinion snubbers and purple shaft cams.
Re: 727 BAND [Re: CMcAllister] #3047367
06/02/22 12:43 PM
06/02/22 12:43 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
We always ran a solid red lined band and a 4.2 lever. If you have a 3.8 lever and a red lined band in stock i would use that combo and not worry about it at all. It will work fine
Re: 727 BAND [Re: CMcAllister] #3047576
06/03/22 08:32 AM
06/03/22 08:32 AM
Byron, NY
Byron, NY
iagree
'60 Willys CJ5
Re: 727 BAND [Re: W.I.N. Racing] #3047582
06/03/22 09:53 AM
06/03/22 09:53 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Hey! I resemble that remark.....LOL
Joe
Re: 727 BAND [Re: jlatessa] #3047624
06/03/22 01:07 PM
06/03/22 01:07 PM
moparx Offline
moparx  Offline
i bought two 5.0 levers from direct connection years ago. they are still in their packaging somewhere in my "stuff" accumulation. biggrin
beer
