70 Challenger 318 upgrade 440 etc. #3047299
06/02/22 08:04 AM
06/02/22 08:04 AM
Massachusetts, USA
MASSMOPAR Offline OP
Massachusetts, USA
I want to drop a crate 440/425hp engine into the 318 base Challenger.
Any requirements, recommendations and suggestions in regard
upgrades to transmission, rear end, brakes, suspension, cooling, exhaust etc ?
thanks
70 Road Runner 528 HEMI 4sp FY1 70 Road Runner 440+6 V-Code AG 4spd EV2 69 R/T 4 Spd Dana 3:54 AG Vert B5 69 R/T 4 Spd Dana 3:54 AG X9 V1X V8R-WORKING 69 R/T Auto/Console 8.75 SG Vert R/T B3 08 Challenger 1st Edition Hemi Orange 69 Super Bee 4 Spd 8.75 SG AG F8
Re: 70 Challenger 318 upgrade 440 etc. [Re: MASSMOPAR] #3047308
06/02/22 09:02 AM
06/02/22 09:02 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Make a list of what is under the car now and we may be able to make some suggestions. You do know that just about anything that connects to the small block will need to be changed for the big block, don't you?
Master, again and still
Re: 70 Challenger 318 upgrade 440 etc. [Re: DaveRS23] #3047312
06/02/22 09:26 AM
06/02/22 09:26 AM
Massachusetts, USA
Massachusetts, USA
Its a stock 318 challenger -
I don't believe the k-frame needs to change?
I know for sure need to change the auto transmission to 727,
drive shaft, rear end axle and differential.
ADD sway bars front and rear, HD brakes and
HD torsion bars.
Re: 70 Challenger 318 upgrade 440 etc. [Re: MASSMOPAR] #3047334
06/02/22 10:58 AM
06/02/22 10:58 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
HD torsion bars.
I think you need to find out what you have before you start ordering parts.
My 73 Challenger had a 318 and came with an 8 3/4 rear axle. No need to change that out. If you currently have a 727 you can keep the driveshaft.
Sway bars aren't required, per se but you may already have a front one.
What brakes do you currently have?
Re: 70 Challenger 318 upgrade 440 etc. [Re: MASSMOPAR] #3047337
06/02/22 11:09 AM
06/02/22 11:09 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
You could easily get that horsepower from a stroked small block and save a bunch of money with much less BS. twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: 70 Challenger 318 upgrade 440 etc. [Re: fourgearsavoy] #3047342
06/02/22 11:34 AM
06/02/22 11:34 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
yeah i second that. you can run the 318 and get 425 hp. whats the plans for the car? driver? street/strip? a 425 hp 440cuin engine is basically a stock rebuild with some aftermarket heads.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: 70 Challenger 318 upgrade 440 etc. [Re: Jerry] #3047353
06/02/22 12:04 PM
06/02/22 12:04 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Lot of difference between a small block and big block handling.
Re: 70 Challenger 318 upgrade 440 etc. [Re: MASSMOPAR] #3047357
06/02/22 12:16 PM
06/02/22 12:16 PM
IMGTX Offline
IMGTX  Offline
HD torsion bars.
K Frame is the same. All V8's except the Hemi had the same basic Kframe.
Motor Mount isolators are the same, (Rubber part)
Motor Mount Brackets (Metal bracket on engine to Rubber isolator) are different.
Transmission mount and isolator are the same.
1970 floor shift cars had a shift interlock linkage. It is not needed if you lock the shift tube in the column and it is a floor shift car. If you keep it, then it will be different big block to small block and 904 to 727
If the transmission is already a 727 floor shift then New transmission and kickdown linkage are needed but all else is the same.
If the transmission is a floor shift 904 then:
The bracket that holds the lower part of the shifter bellcrank is different,
The kickdown linkage is different
Probably the Rod to the shift lever.
Driveshaft and slip yoke are different too.
Of course you need the 727 Transmission.
Column shift cars need the correct bracket for the shift linkage for the Big Block. Nearly all linkage if swapping from 904 to 727. I doubt it is column shift. Not many column shift Challengers.
Rear end is OK if it is and 8-3/4, Gear change is optional.
Sway bar is a nice plus. Can be left off but really worth it in my opinion.
Torsion bars will need to be replaced and if you drive hard the rear springs will probably need to be looked at.
Exhaust is different and you would want duals instead of single anyway.
Engine wiring is slightly different. A new engine harness or modify the old one.
Power steering brackets and probably hoses.
If you have/want AC the brackets and hoses are different.
Radiator, fan shroud and hoses need replaced if it is still stock.
Not a hard job except finding or paying for the linkage.
Re: 70 Challenger 318 upgrade 440 etc. [Re: IMGTX] #3047392
06/02/22 02:03 PM
06/02/22 02:03 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Me, I'd go with a stroked LA unless I absolutely needed 440 CI.
Did that on a Duster street car, and loved it.
Re: 70 Challenger 318 upgrade 440 etc. [Re: topside] #3047478
06/02/22 07:55 PM
06/02/22 07:55 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I agree. A 408 with the right cam and good heads would be a lot shorter route and the car will drive better with the lighter power plant. If it's got a 904, stay with it. Just beef it some.
Re: 70 Challenger 318 upgrade 440 etc. [Re: DaveRS23] #3047553
06/03/22 12:40 AM
06/03/22 12:40 AM
Long Island, New York
57Fury440 Offline
57Fury440  Offline
He said he has a 1970 with a 318. That should have the small rear end. He will need an 8&3/4 rear behind the 440. All E bodies 1972 and up came with the 8&3/4 rear but not in 1970. I like the idea of the stroked LA motor. E bodies ride and handle better with small blocks.
Re: 70 Challenger 318 upgrade 440 etc. [Re: 57Fury440] #3047563
06/03/22 06:30 AM
06/03/22 06:30 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
I can't knock small blocks but putting your foot in a big block will put a smile on you face. I did this swap but with a 383. Definitely get the lager torsion bars, I was lucky and found a set in a junk yard.
Re: 70 Challenger 318 upgrade 440 etc. [Re: IMGTX] #3047578
06/03/22 09:14 AM
06/03/22 09:14 AM
Massachusetts, USA
Massachusetts, USA
Appreciate the idea and suggestions to stroke the 318...
This is what I have:
1970 Challenger 318, floor shift 904 and 7 1/4 rear end.
and a Crate 440
To summarize needs: Appreciate info where I can purchase these items:
- Motor mounts and brackets
- The bracket that holds shifter bell crank -
- Kick down linkage for 727
- Rod to shift lever
- Drive shaft and slip yoke
- 727 Transmission
- 8 3/4 rear end
- sway bars -front and rear
- torsion bars
- dual exhaust
- power steering brackets/hoses
- Radiator and hoses.
Re: 70 Challenger 318 upgrade 440 etc. [Re: MASSMOPAR] #3047579
06/03/22 09:26 AM
06/03/22 09:26 AM
Massachusetts, USA
Massachusetts, USA
pics
Re: 70 Challenger 318 upgrade 440 etc. [Re: MASSMOPAR] #3047581
06/03/22 09:47 AM
06/03/22 09:47 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
You have a big (and expensive) job ahead of you there. It might be a challenge finding everything you need for it right now. You have the large radiator opening, that is a good start. I do have a couple of questions up front;
Do you plan to keep the A/C with the 440? Do you have the standard flat hood? And then, is there a time or money budget on this project?
Re: 70 Challenger 318 upgrade 440 etc. [Re: MASSMOPAR] #3047583
06/03/22 10:10 AM
06/03/22 10:10 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I will make a couple of suggestions on the shift linkage; lock out the shift interlock rather than mess with redoing it. Just make up a one piece kick down like the later models had. I usually make my own from Dodge trucks in the pick-a-part yards. The key is getting the right ratio between the carb arm and the arm on the tranny. Make sure that the 727 you get has the mount on the tail shaft for the shift rod arm. You see the arms at the Mopar swap meets regularly and they are in repop, too. Is the 904 arm different than the 727 arm? Year One shows them all on back-order and only lists a 727 arm.
Re: 70 Challenger 318 upgrade 440 etc. [Re: DaveRS23] #3047585
06/03/22 10:17 AM
06/03/22 10:17 AM
Massachusetts, USA
Massachusetts, USA
Have the flat hood - intend to go with AMD shaker and a shaker kit 4bbl.
Have A/C Intend to remove A/C.
Have 7 1/4 intend to get a Mopar Madness 8 3/4 complete brakes
I'm committed to the project - time not an issue - money is always a concern.
Before starting I like to have all the components on hand already have the car and the crate engine.
What parts in your mind are gonna be an issue/challenge to get?
Here is a list thus far...
- 727 Transmission
- 8 3/4 rear end
- torsion bars
- dual exhaust
- HD leaf springs
Re: 70 Challenger 318 upgrade 440 etc. [Re: MASSMOPAR] #3047586
06/03/22 10:22 AM
06/03/22 10:22 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Save yourself a LOT of time, money and effort, sell this car unmolested and buy an already built 440 Challenger. 2ยข
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: 70 Challenger 318 upgrade 440 etc. [Re: MASSMOPAR] #3047587
06/03/22 10:29 AM
06/03/22 10:29 AM
IMGTX Offline
IMGTX  Offline
Do you want it to look stock or is aftermarket ok?
Lots of options open up if you go aftermarket. Radiators, exhaust, kiickdown, swaybars, etc are available aftermarket and can be a better option sometimes. Also if you want original then you will be looking for early 70's 440 parts but non original opens options on brackets, pulleys etc from different years that may be more easily available.
Re: 70 Challenger 318 upgrade 440 etc. [Re: IMGTX] #3047593
06/03/22 11:02 AM
06/03/22 11:02 AM
Massachusetts, USA
Massachusetts, USA
Aftermarket parts are fine.- availability is more important.
