Dash Pad on 70 B Body #304634
05/01/09 05:27 PM
05/01/09 05:27 PM
Kentucky, USA
RoadrunnerCN Offline OP
Kentucky, USA
I know I've seen a post on this, but can't find it. Sorry, tried to search. I'm replacing the entire dash unit, have it all out. The foam dash pad that bolts to the dash board is out. Needs replacing. I'd rather not buy a cover since I did all the work to pull it out, but have two questions: 1.) Where's a good recommendation to send it to have it redone (new foam and vinyl on the core)? I know it can be pricey. I'd like a decent job, but doesn't have to be show car quality. 2.) What's your best recommendation for a cover if I went that route. Saw some on E-bay for as little as $54, $80, on up. Thoughts? Thanks. Chris.
Re: Dash Pad on 70 B Body [Re: RoadrunnerCN] #304635
05/01/09 08:13 PM
05/01/09 08:13 PM
central new york
pettyblue440 Offline
central new york
BE&A makes a dash pad now. That is probably your best bet
Re: Dash Pad on 70 B Body [Re: pettyblue440] #304636
05/01/09 09:26 PM
05/01/09 09:26 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Call Mike Ross at BEA parts,......you can't go wrong
Re: Dash Pad on 70 B Body [Re: RoadrunnerCN] #304637
05/02/09 07:31 AM
05/02/09 07:31 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Re: Dash Pad on 70 B Body [Re: gtx6970] #304638
05/04/09 03:09 PM
05/04/09 03:09 PM
Kentucky, USA
Kentucky, USA
Thanks all for responding and for posting the previous link. Chris.
