Need somebody to look at their 440 with ps and ac for me #3046038
05/29/22 12:33 AM
05/29/22 12:33 AM
Someplace you aren't
SomeCarGuy Offline OP
My car had a hardware store bolt stuck in this location and I’m not sure it needed one to begin with. I changed to resto fan belts today and took the bolt out since it was rubbing occasionally on the back belt. The set on there had one super tight and the rear belt was just a bit more slack. New set isn’t like that and could probably clear the bolt, but it looks stupid and will always be a risk as a belt stretches. Power steering pump seems secure without a bolt in this spot. The sort of chewed up looking hole is where it was.
It would maybe work with the bolt turned around if I can get a wrench on it. Would rather have a factory bolt if one is needed though. Wildcat Wrecking never got back to me when I asked them a few weeks ago.
Appreciate somebody taking a pic or at least confirming what they have. It’s possible this is the wrong power steering pump or bracket setup as both a resto power steering belt and a common modern replacement belt I ordered are about a mile too short. This car does not have the classic “one finger” effort my other power cars had. Maybe just an issue of a bigger pulley cutting the assist back? That would explain the longer belt needed.
This is a 69 GTX with 440 with ac and power steering.
I want my fair share
Re: Need somebody to look at their 440 with ps and ac for me [Re: SomeCarGuy] #3046050
05/29/22 05:03 AM
05/29/22 05:03 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
That’s a federal pump from looking on my phone. All of my 69 cars have the Saginaw pump. It’s a better pump and able to keep up with the pressure needs. The federal pump requires different regulation valves for each different application and they only came that way from the factory. If you got a rebuilt pump, no telling which valve you got. Dragon slayer is the man to talk about federal pumps. The only federal pumps on 69 still were c bodies, Hemi and small blocks. The TA/AAR federal pumps got the same pressure valve as a big c body in 70. Dragon knows more and has pictures. I’d get me a saginaw pump. The square hole you are showing is for a 1/2” drive breaker bar or ratchet to tighten it, not a bolt.
Re: Need somebody to look at their 440 with ps and ac for me [Re: fastmark] #3046051
05/29/22 05:14 AM
05/29/22 05:14 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
This is a 70 Charger 440 with factory air
Re: Need somebody to look at their 440 with ps and ac for me [Re: fastmark] #3046052
05/29/22 05:17 AM
05/29/22 05:17 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
This is a 69 Charger 440 with added AC but retaining the factory saginaw pump.
Re: Need somebody to look at their 440 with ps and ac for me [Re: fastmark] #3046065
05/29/22 08:18 AM
05/29/22 08:18 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
The mangled hole appears to be square hole you'd put a ratchet into for tensioning the belt.
No bolt goes there.
Angry white pureblood male
Re: Need somebody to look at their 440 with ps and ac for me [Re: ruderunner] #3046197
05/29/22 03:42 PM
05/29/22 03:42 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
No bolt goes there.
That's right
Re: Need somebody to look at their 440 with ps and ac for me [Re: CYACOP] #3046264
05/29/22 09:12 PM
05/29/22 09:12 PM
Thanks guys
The pulley looks to be the same size as what is pictured here. It’s way to big to fit a correct for the car belt.
Would a Saginaw lump bolt up to the bracket I have? Did they make those in a similar style to the federal pump? The Saginaw s I had were all later and had the teardrop shape, not even close to a federal in look. Also there is a trw pump that from what I know has a similar shape to the federal.
Re: Need somebody to look at their 440 with ps and ac for me [Re: SomeCarGuy] #3046322
05/30/22 12:13 AM
05/30/22 12:13 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
TRW , Saginaw and Federal pumps are take their own special mounting brackets
Re: Need somebody to look at their 440 with ps and ac for me [Re: gtx6970] #3046358
05/30/22 08:12 AM
05/30/22 08:12 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Correct. Bouchillon sells the brackets and pulley. You can find them for sale here. I saw one on for b bodies only the other day. They run about $200 or less.
