On the main harness there is a connector which goes to the road lamp harness but on the road lamp harness there is another similar connector that is called "to H/LP on reminder buzzer wiring" - I haven't found the wiring past this. The connectors are the V shaped ones, not the T shaped if that helps. Any dash pics of the wiring in this area would be helpful
- Steve
