MSD and stock wiring harness? UPDATE #304581
05/01/09 04:41 PM
05/01/09 04:41 PM
S.W. Ohio
clyde Offline OP
clyde  Offline OP
S.W. Ohio
Msd 6al mallory distributor stock harness battery in trunk and master switch. Heres the problem, red wire from msd to red wire coming from steering column, car starts but wont shut off with key switch but will at master switch. So which wire do I hook it to? Any help will be appreciated, Thanks Randy
Hats off to Healthservices! Hooked brown to blue and MSD and Viola! It now works like I intended it to. Thanks again Healthservices
Re: MSD and stock wiring harness? [Re: clyde] #304582
05/01/09 05:37 PM
05/01/09 05:37 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
You must be on a power line and not an ignition on line?
more info
Re: MSD and stock wiring harness? [Re: clyde] #304583
05/01/09 05:38 PM
05/01/09 05:38 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
try it with key off and jump relay it will probably start!
Re: MSD and stock wiring harness? [Re: Dodgem] #304584
05/01/09 05:41 PM
05/01/09 05:41 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Check the msd small red wire sounds like its hot all the time
Re: MSD and stock wiring harness? [Re: emarine01] #304585
05/01/09 05:54 PM
05/01/09 05:54 PM
S.W. Ohio
clyde Offline OP
clyde  Offline OP
S.W. Ohio
Yes small red wire is hot all the time. It is connected to the red wire coming out of column. From what I can tell from wiring diagrams is it should be on blue wire with tracer or brown wire or yellow wire all of which come out of column. If I jump to blue wire car will start but, only run if I hold starter engaged same with yellow wire. Brown wire and no start at all. Thx Randy
Re: MSD and stock wiring harness? [Re: clyde] #304586
05/01/09 06:01 PM
05/01/09 06:01 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Just brake out a test light and find a keyed hot thats hot while its cranking and in the run position when you let off the starter & turns off with the key
Re: MSD and stock wiring harness? [Re: emarine01] #304587
05/01/09 06:08 PM
05/01/09 06:08 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Run the wire to a "switched" terminal on your fuse block.
Is it a stock fuse block or?
Re: MSD and stock wiring harness? [Re: clyde] #304588
05/01/09 06:09 PM
05/01/09 06:09 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Jump the Brown wire and the dark blue/trc together and connect to your small red wire on the MSD
Brown gives power only during crank . giving full 12 volts to coil
dark blue/trc gives power only with the key on . It feeds the coil thru the resister.
The MSD small red wire just needs this power lead as a signal wire to sower on the MSD, voltage is not a concern.
Double check what I colored for you.
Re: MSD and stock wiring harness? [Re: clyde] #304589
05/01/09 06:21 PM
05/01/09 06:21 PM
S.W. Ohio
clyde Offline OP
clyde  Offline OP
S.W. Ohio
UHHH did I mention it's a 70 barracuda?
Re: MSD and stock wiring harness? [Re: cgall] #304590
05/01/09 06:25 PM
05/01/09 06:25 PM
S.W. Ohio
clyde Offline OP
clyde  Offline OP
S.W. Ohio
Stock fuse block and wheres yer oil pan?
Re: MSD and stock wiring harness? [Re: clyde] #304591
05/01/09 06:27 PM
05/01/09 06:27 PM
So Cal
So Cal
I'll check it if you like but it looks to be the same wires.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: MSD and stock wiring harness? [Re: HealthServices] #304592
05/01/09 06:30 PM
05/01/09 06:30 PM
S.W. Ohio
clyde Offline OP
clyde  Offline OP
S.W. Ohio
I should get voltage at the brown wire right? Problem is there no voltage at said wire. Beginning to think ign switch is bad.
Re: MSD and stock wiring harness? [Re: clyde] #304593
05/01/09 06:32 PM
05/01/09 06:32 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Oil pan is on bench, has 4 small cracks. I will bring it up if I ever get a spare hour or two, you weld and I'll solder wires!
Re: MSD and stock wiring harness? [Re: clyde] #304594
05/01/09 06:38 PM
05/01/09 06:38 PM
So Cal
So Cal
Brown hot only during cranking
If it is cut make sure you are connecting to the wire leading to the ignition and not leading to the engine compartment.
Re: MSD and stock wiring harness? [Re: HealthServices] #304595
05/01/09 06:49 PM
05/01/09 06:49 PM
S.W. Ohio
clyde Offline OP
clyde  Offline OP
S.W. Ohio
It could be my test light but I dont think I was getting voltage at brown while cranking but I will try again. Thanks for the help Greatly appreciated.
Re: MSD and stock wiring harness? [Re: cgall] #304596
05/01/09 06:52 PM
05/01/09 06:52 PM
S.W. Ohio
clyde Offline OP
clyde  Offline OP
S.W. Ohio
Lessee I solder pan, you weld wires or something like that
Re: MSD and stock wiring harness? [Re: clyde] #304597
05/01/09 07:33 PM
05/01/09 07:33 PM
So Cal
So Cal
oh and make sure you are not grabing the brown wire from the turn signal connector.
Re: MSD and stock wiring harness? [Re: HealthServices] #304598
05/01/09 07:41 PM
05/01/09 07:41 PM
S.W. Ohio
clyde Offline OP
clyde  Offline OP
S.W. Ohio
That fixed it. Thanks again. Randy
Re: MSD and stock wiring harness? [Re: clyde] #304599
05/01/09 07:46 PM
05/01/09 07:46 PM
So Cal
So Cal
