Re: Need radiator recommendation
[Re: AndyF]
#3045703
05/27/22 07:01 PM
05/27/22 07:01 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
If price is not that big of a concern, i am very happy with the Griffen aluminum read I put in my 68 b body. I got the direct replacement one and painted it black with radiator paint. . It looks close to stock without tank numbers. Brackets welded to rad and bolt exactly like stock. It has (2) 1-1/4” cooling rows and keeps my rb stroker cool on hot days. I use the factory shroud which bolts up exactly like stock. Very impressed with quality.
[Re: Chargerfan68]
#3045718
05/27/22 08:18 PM
05/27/22 08:18 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
Use the corresponding 22" core and have the inlet/out setup for a big block. Then have a heavy duty high density 4 core put in it. 67-69 Big Block 383 core radiators (tanks w/straps) are big buck for a the stamped numbers.
This one was done by Glen Ray radiator. It doesn't have a shroud because the 68 Super Stock weren't delivered with one.
It's driven on the street often with not overhead issues and a 472 Hemi automatic.
[Re: 440mopar]
#3045799
05/28/22 09:09 AM
05/28/22 09:09 AM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
Here is another option for you. I had them build a 4 row copper & brass High efficiency 22" for my 68 road runner . All mounting points were correct including the fan shroud. They offer alum. as well. https://usradiator.com/product/dodge-dart-1967-69-v8-bb-radiatorMark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: 440mopar]
#3045851
05/28/22 11:51 AM
05/28/22 11:51 AM
Posts: 31,036 Oregon
AndyF
I will look into the Griffen and Glen Ray radiators. I don't care if there are any numbers on it as the car is not original anyway but I will also look around for a factory big block radiator. I have a related cooling question as well. As far as the fan/clutch go, I was planning on using a Mopar Performance viscous fan kit I have in my collection of parts. It is the kit with the five blade fan. Will the five blade fan work well or should I go with a factory seven blade fan? I don't think you'll have enough room for that clutch fan. The BB A body cars are usually really short of space unless you've made modifications. Have you ever had this car together or is this the first time? I used a 26 inch radiator in my Duster and I found room for a clutch fan, but I had to move a lot of stuff around.
[Re: AndyF]
#3045882
05/28/22 01:19 PM
05/28/22 01:19 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
I had mine custom made for my car. Included a shroud and 2 Derale electric fan. Keeps my street/strip car cooler on the street than my more stock street cars. I added -20 aluminum bungs for the upper and lower hoses and a -6 for the over flow.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
