B&M cast aluminum tranny pan/bolts? #3045587
05/27/22 10:50 AM
05/27/22 10:50 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Anyone uses the blue lock tight on them?. Semes like i cant keep them tight runaway
Re: B&M cast aluminum tranny pan/bolts? [Re: racerx] #3045589
05/27/22 11:00 AM
05/27/22 11:00 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I use 271 red on my powerglides.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: B&M cast aluminum tranny pan/bolts? [Re: racerx] #3045591
05/27/22 11:05 AM
05/27/22 11:05 AM
Kirkland, Washington
Pacnorthcuda Offline
Are you sure it’s not simply gasket crush? You could mark (clock) he bolts and check to see if there is any rotation over time.
Re: B&M cast aluminum tranny pan/bolts? [Re: Pacnorthcuda] #3045626
05/27/22 12:46 PM
05/27/22 12:46 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
It was touque down with a inch pound wrench per manual recommendation doing the rebuild, all was good for a few weeks then that drip mad when i went to snug it seems they were a little loser than i thought they should have been shruggy
Re: B&M cast aluminum tranny pan/bolts? [Re: pittsburghracer] #3045629
05/27/22 12:48 PM
05/27/22 12:48 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Pittsb...is that with stainless bolts?
Re: B&M cast aluminum tranny pan/bolts? [Re: racerx] #3045638
05/27/22 01:02 PM
05/27/22 01:02 PM
PA.
"Little"John
"Little"John
PA.
I’ve been using a lot of Tractor Supply grade 8 because I can buy them by the pound. But yes I have used stainless and it works great on those too. Everyone gets stuck on the term “removeable”. Heck I use 271 on my oil pan bolts, flywheel bolts, converter bolts, cam bolts, etc.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: B&M cast aluminum tranny pan/bolts? [Re: Pacnorthcuda] #3045656
05/27/22 01:58 PM
05/27/22 01:58 PM
A727Tflite Offline
A727Tflite  Offline
iagree
All cork, rubber coated cork take a compression set over time.
Re: B&M cast aluminum tranny pan/bolts? [Re: A727Tflite] #3045705
05/27/22 07:19 PM
05/27/22 07:19 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Thanks for the reply.. Trans, but it's rubber.
Re: B&M cast aluminum tranny pan/bolts? [Re: racerx] #3045708
05/27/22 07:23 PM
05/27/22 07:23 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Lube locker is a nice reusable pan gasket. Never leaked for me.
Re: B&M cast aluminum tranny pan/bolts? [Re: racerx] #3045717
05/27/22 08:18 PM
05/27/22 08:18 PM
A727Tflite Offline
A727Tflite  Offline
Pure rubber without compression limiters?
Re: B&M cast aluminum tranny pan/bolts? [Re: A727Tflite] #3045722
05/27/22 08:37 PM
05/27/22 08:37 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Yes sir.
Re: B&M cast aluminum tranny pan/bolts? [Re: racerx] #3045728
05/27/22 09:11 PM
05/27/22 09:11 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Don't use loctite on the bolts. It's probably seeping through the pan holes. Put silicone in the pan holes and then snug it down tight.
Those pans are notorious for leaking.
Silicone on the pan rail then put down the gasket.
Put it up and let the silicone dry overnight and then tighten down the bolts.
Re: B&M cast aluminum tranny pan/bolts? [Re: Sammy] #3045734
05/27/22 09:31 PM
05/27/22 09:31 PM
PA.
"Little"John
"Little"John
PA.
Nope. No silicon on the pan gasket.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: B&M cast aluminum tranny pan/bolts? [Re: pittsburghracer] #3045739
05/27/22 09:43 PM
05/27/22 09:43 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Mopar reusable gasket at 130inlb been working like a champ for me for a long time. But I just use steel RE pans smile
Re: B&M cast aluminum tranny pan/bolts? [Re: J_BODY] #3045774
05/28/22 06:38 AM
05/28/22 06:38 AM
A727Tflite Offline
A727Tflite  Offline
I can’t imagine any better gasket than the reuseable Mopar gasket, especially on a cast aluminum pan.
Re: B&M cast aluminum tranny pan/bolts? [Re: A727Tflite] #3046023
05/28/22 10:38 PM
05/28/22 10:38 PM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
^^^ ...this....never a leak with a B&M deep pan.
Re: B&M cast aluminum tranny pan/bolts? [Re: LAD 524] #3046054
05/29/22 05:48 AM
05/29/22 05:48 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
So who carry this mopar gasket? Any site sponsors?
Re: B&M cast aluminum tranny pan/bolts? [Re: racerx] #3046067
05/29/22 08:24 AM
05/29/22 08:24 AM
A727Tflite Offline
A727Tflite  Offline
Available from all FCA dealers. Just tell the parts guy you need the factory pan gasket for a 2003 - 2007 48RE.
Re: B&M cast aluminum tranny pan/bolts? [Re: A727Tflite] #3046070
05/29/22 08:51 AM
05/29/22 08:51 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Thanks Trans... up
Re: B&M cast aluminum tranny pan/bolts? [Re: racerx] #3046111
05/29/22 11:15 AM
05/29/22 11:15 AM
A727Tflite Offline
A727Tflite  Offline
Thanks Trans... up
Looks like it is 2464324AC. Verify with dealer to be sure.
