Page 3 of 3 1 2 3
Re: Fusible Link [Re: RapidRobert] #304498
05/08/09 07:58 PM
05/08/09 07:58 PM
Babylon,NY
440_ci Offline OP
440_ci  Offline OP
Babylon,NY
I was referencing the "cranks but no start" section ofhttp://www.moparaction.com/Tech/archive/roadside.html when they said you should be getting at least 8 volts to the + side of the coil and i am getting a steady 6, is this too little or should it still work?
Re: Fusible Link [Re: 440_ci] #304499
05/08/09 08:11 PM
05/08/09 08:11 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
It isn't that complicated. You're making it way harder than it needs to be. You tested the coil and it didn't work. Replace it and go from there.
Re: Fusible Link [Re: stumpy] #304500
05/09/09 03:48 PM
05/09/09 03:48 PM
Babylon,NY
440_ci Offline OP
440_ci  Offline OP
Babylon,NY
........okay its really getting hard to keep my calm now. I just tried it with a new coil and still no spark.. I am getting 12volts to every point i am supposed to and all wires/pieces are showing good continuity but still i have zero spark.
Re: Fusible Link [Re: 440_ci] #304501
05/09/09 03:53 PM
05/09/09 03:53 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Are you getting voltage during cranking or just when the key is on?
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Fusible Link [Re: HealthServices] #304502
05/09/09 04:00 PM
05/09/09 04:00 PM
Babylon,NY
440_ci Offline OP
440_ci  Offline OP
Babylon,NY
I get voltage both times which is why i kept thinking it was the ecu or coil and not some wires, but now i am just stumped on what else it could be.
Re: Fusible Link [Re: HealthServices] #304503
05/09/09 04:01 PM
05/09/09 04:01 PM
12V to coil primary terminal(for several seconds only).jumper from coil primary negative terminal to ground(make/break like morse code) with the orig wire from this terminal to the ECU disconnected. Coil secondary wire plugged solidly into coil center & other end held 1/4" from ground. Not being patronizing but keeping it simple in this time of need.
Re: Fusible Link [Re: RapidRobert] #304504
05/09/09 04:22 PM
05/09/09 04:22 PM
So Cal
So Cal
Sorry if you were here it, I'd isolate the system, jumper the nec. wires and go from there to get it started, then back track whatever is nec.
What is simple for me is not nec. so for you.
Re: Fusible Link [Re: HealthServices] #304505
05/09/09 04:24 PM
05/09/09 04:24 PM
Babylon,NY
440_ci Offline OP
440_ci  Offline OP
Babylon,NY
So basically try what Robert said again? And that is the method that you cant leave the car running for too long or else it can damage the ignition right?
Re: Fusible Link [Re: 440_ci] #304506
05/09/09 04:28 PM
05/09/09 04:28 PM
So Cal
So Cal
Doing what Robert says will diagnose what is the problem if it is in the ignition system. You do want to make sure if the ignition system is working.
I'm just wondering if you are disconnecting any wires when you are 'bench testing' the system.
Re: Fusible Link [Re: HealthServices] #304507
05/09/09 08:22 PM
05/09/09 08:22 PM
Babylon,NY
440_ci Offline OP
440_ci  Offline OP
Babylon,NY
Okay i just tried what Robert said again and still no spark.I hear a popping or clicking noise though (from where i cant be sure right now since its just me, but its from somewhere in the engine bay) when ever i turn off the key from the 'on' position, mean anything to ya?
Re: Fusible Link [Re: 440_ci] #304508
05/20/09 12:20 PM
05/20/09 12:20 PM
Babylon,NY
440_ci Offline OP
440_ci  Offline OP
Babylon,NY
bump
Re: Fusible Link [Re: ETASPEN] #304509
06/14/09 06:26 PM
06/14/09 06:26 PM
Toronto, Ont, Canada
boydsdodge Offline
boydsdodge  Offline
I am gonna jump in here a lil late but need to ask, I am having overheated wiring probs as well and when I disconnect the main bat feed from the alt the sparks and melting stop.
Does this mean my alt is the short?
I hope so because they are a lot easier to swap out.
Re: Fusible Link [Re: boydsdodge] #304510
06/14/09 07:26 PM
06/14/09 07:26 PM
You need to start a separate thread with your question
Re: Fusible Link [Re: 440_ci] #304511
06/14/09 09:45 PM
06/14/09 09:45 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
You need a helper. I can see not wanting to leave it on when you are by yourself.
I would say you could just leave the battery dummy hooked and run out there yourself in a pinch. Do the key through the window and be quick about it.
I had a bad VR that made a sound like a clicking one time. It would work and then click off and then click on again, even with a good ground.
Page 3 of 3 1 2 3
