Re: Melonized Gear on Billet Roller Core
[Re: 6PakBee]
#3044877
05/24/22 04:36 PM
05/24/22 04:36 PM
Posts: 4,699 Wichita
GY3
Wichita
I've used the Crane melonized on a Howards hydraulic roller for a few years now. Lots of miles and lots of passes.
In fact, I just had the engine apart this Winter for refresh and the gear showed little to no wear. Standard volume, standard pressure oil pump.
[Re: Torquemonster440]
#3044902
05/24/22 06:34 PM
05/24/22 06:34 PM
Posts: 2,677 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Mainly gonna be a street driver because there are no 1/4 mile tracks in So.Cal anymore.
WOW, when I was young there were many. Lots of Top Fuel nights.
2011 Drag Pak Challenger
[Re: NITROUSN]
#3044927
05/24/22 08:10 PM
05/24/22 08:10 PM
Posts: 179 California, U.S.A.
Torquemonster440
California, U.S.A.
Bullet told you what to use. Maybe they told you that by experience and reason. Just saying. I realize that, that's why I mentioned it. Of course Bullet is gonna give me the safe proven answer, but that doesn't guarantee long term success with the bronze gear either. (Lots of failures with bronze if you search the forums).Thats why I asked the question,.. if anyone had first hand experience with a Melonized gear on a billet roller? Hughes says I'm good.. btw.. but, they also want to sell me a Melonized gear... The melonized gear situation seems like uncharted waters for most Mopar guys. So,.. Who's right? Hughes or Bullet ?
1966 Satellie.. 12.55 @107.75. 906 heads. 3780 lbs.
[Re: rickseeman]
#3044933
05/24/22 08:22 PM
05/24/22 08:22 PM
Torquemonster440
California, U.S.A.
WOW, when I was young there were many. Lots of Top Fuel nights. Yep..pretty sad state of affairs out here for a drag racer anymore.
[Re: GY3]
#3044948
05/24/22 08:57 PM
05/24/22 08:57 PM
Torquemonster440
California, U.S.A.
In fact, I just had the engine apart this Winter for refresh and the gear showed little to no wear. Standard volume, standard pressure oil pump. Is that a billet core Hydraulic Roller ?
#3044952
05/24/22 09:07 PM
05/24/22 09:07 PM
Posts: 43,284 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#3044991
05/24/22 10:44 PM
05/24/22 10:44 PM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
I'm running a melonized gear on an 8620 core. I don't have enough miles on it to know how it will do long term.
Agreed on minimizing travel with cam button. I'm using Andy's timing cover, nylon button, .002.
I think running excessively thick oil or too heavy of a bypass spring could put more load on the gears than needed as well.
[Re: INTMD8]
#3045009
05/24/22 11:54 PM
05/24/22 11:54 PM
Torquemonster440
California, U.S.A.
[quote=INTMD8]I'm running a melonized gear on an 8620 core. I don't have enough miles on it to know how it will do long term.
I think running excessively thick oil or too heavy of a bypass spring could put more load on the gears than needed as well. [/quote Nice, a Hughes brand Melonized gear?.. have you inspected it since install ? The cam thrust endplay is another point of contention, I see anywhere between.. .002 and .013.. ? I have mine currently set up at .008. Hopefully. 008 will be sufficient? Any further details regarding your experience will be much appreciated.
#3045050
05/25/22 08:47 AM
05/25/22 08:47 AM
GY3
Wichita
In fact, I just had the engine apart this Winter for refresh and the gear showed little to no wear. Standard volume, standard pressure oil pump. Is that a billet core Hydraulic Roller ? Not sure. All the places I have found that have it for sale don't show what material the cam core is.
[Re: LAD 524]
#3045059
05/25/22 09:32 AM
05/25/22 09:32 AM
Posts: 1,165 Loudoun County, VA
Brad_Haak
Loudoun County, VA
I believe the Hughes gear in actually a Crane gear Pt # CR66970-1.
That's my understanding, although maybe there's another source since Crane is no longer in business. Re shaft, I purchased mine from Hughes installed on one of their shafts. The only thing I wasn't thrilled about was the slot in the shaft where the tab on the distributor shaft fits is wider than OEM; I had to on the distributor shaft tip to flare it out enough to take up the slop.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
#3045069
05/25/22 10:17 AM
05/25/22 10:17 AM
INTMD8
Lake Villa Il
Yes from Hughes, as LAD mentioned, I believe it's the Crane gear. I would think .008 is fine. I have not inspected it yet. Just drove it to the dyno and back (plus runs on the dyno) so maybe a couple hundred miles on it tops.
[Re: INTMD8]
#3045282
05/26/22 09:10 AM
05/26/22 09:10 AM
Torquemonster440
California, U.S.A.
Yes from Hughes, as LAD mentioned, I believe it's the Crane gear. I would think .008 is fine. I have not inspected it yet. Just drove it to the dyno and back (plus runs on the dyno) so maybe a couple hundred miles on it tops. ⁹ Ok, thanks for the feedback. Much appreciated .
