Rear disc brake conversion #3044274
05/22/22 11:45 AM
05/22/22 11:45 AM
Oak Harbor, WA
W
Wicked49670dart Offline OP
W
Oak Harbor, WA
Trying to convert my 70 Dart 8 3/4 from 10" drum to rear disc brakes. My axle offset is 2.185", all the kits I have tried are (Wilwood 2.36 and 2.50) and the rotor hits the adapter mounting bolts and bracket. The axles are Moser with there MO400 bearing. Anyone ran into this issue? Thanks Matt
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: Rear disc brake conversion [Re: Wicked49670dart] #3044304
05/22/22 01:03 PM
05/22/22 01:03 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
A long time ago I installed Strange rear brakes on the Dana in my 69 Barracuda.
I had some very old Strange axles and had problems with the disk alignment.
The final fix was sending the axles back to Strange and they fixed the problem.
I would check with Strange and with Moser who also sells disk brakes.
Re: Rear disc brake conversion [Re: Wicked49670dart] #3044305
05/22/22 01:06 PM
05/22/22 01:06 PM
moparx Offline
moparx  Offline
aren't the 2.360 and 2.500 offset kits for the B-body rears ?
if so, and using those on an A-body rear with the [factory ?] short 2.185 offset, wouldn't one have to compensate for the offset difference [.315-2.500 offset, .175-2.360 offset] by shimming the bracketry or using hub-centric spacers behind the rotors ?
just thinking out loud about what could be done to use what you have.
others may have other ideas or opinions, so hopefully they will chime in.
beer
Re: Rear disc brake conversion [Re: Wicked49670dart] #3044335
05/22/22 03:01 PM
05/22/22 03:01 PM
AndyF Offline
AndyF  Offline
Take a look at what Doctor Diff has available
Re: Rear disc brake conversion [Re: AndyF] #3044986
05/24/22 10:36 PM
05/24/22 10:36 PM
Oak Harbor, WA
W
W
Oak Harbor, WA
Thanks for every one's help, I purchased the correct kit from Dr Diff. Thanks Matt
