1968-69 Rallye cluster was Dodge only, standard in Super Bee & Charger and optional in Coronet RT.
All 68-69 Rallye clusters had clock as standard and tach optional, so all had the adjustment stem. In 1970 they were available on Plymouth and Dodge models. There was a clock delete plate as standard. Clock or tach were optional. I have never seen a 68-70 B body lens without the hole for adjustment stem. The clips are available in aftermarket, check Ebay.
