Re: Crank Main seals Big Block
[Re: jwb123]
#3042237
05/14/22 12:04 PM
05/14/22 12:04 PM
Posts: 4,741 Moved to N.E. Tennessee
GomangoCuda
I used an aluminum cover, and fabricated a thin ring out of aluminum as a retainer to hold the seal in. Two small allen head screws sealed with rtv, plenty of room to fit behind balancer, did it on several Chevy engines as well. Pics?
[Re: jwb123]
#3042509
05/15/22 02:02 PM
05/15/22 02:02 PM
Posts: 201 Texas
Chief
Texas
Not trying to steal the thread but my question is relevant to the OP.. I run a 8:71 on my BBM. I also run a vacuum pump. I use the Fast Fish rear seal, no leak there. But I'm trying to stop any vacuum leaks at the front seal. I have packed the backside with RTV but I'm not happy with it. I know the chebby crowd has a double lip seal they use on their builds. Anyone have a part number for a double lip seal or a better way to go for a BBM?
Thanks Dave
Dave Covey
[Re: AndyF]
#3042545
05/15/22 04:34 PM
05/15/22 04:34 PM
Posts: 1,049 San Jose Ca.
boatracer572
San Jose Ca.
The NASCAR guys developed a super high vacuum front cover seal. I bought a couple of them years ago when I was developing the billet timing cover for SB Mopars. The seals are expensive and not widely available. I bought mine from some shop in NC, don't recall the name. Tritec seals, before they were bought by a bigger company i bought three upper and lower double lip jesel seals as well as well as 3 double lip rear main high vacuum seals. i recently looked up and found the company that acquired them,im sure they still make the same seals...
[Re: FastmOp]
#3042591
05/15/22 07:30 PM
05/15/22 07:30 PM
Posts: 43,255 Bend,OR USA
Cab_Burge
Have you filled the rear main seal holder edges to the block with adhesive silicone gasket maker yet on the rear main? if not try that, I've seen a lot of rear main seal leaks there, which made the owners, racers, mechanics, think it was the crank seals instead of the side seals leaking: work:: scope: wrench:
[Re: GomangoCuda]
#3042598
05/15/22 07:56 PM
05/15/22 07:56 PM
Posts: 2,673 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
2011 Drag Pak Challenger
[Re: LAD 524]
#3042886
05/16/22 06:55 PM
05/16/22 06:55 PM
Posts: 5,762 Hot Rod Ridge
FastmOp
Hot Rod Ridge
So I dug this out but I need the crank gear. And prolly some shims or a setup kit. Never messed with this stuff before.
Can I order just the crank gear and setup kit.
[Re: FastmOp]
#3043129
05/17/22 05:36 PM
05/17/22 05:36 PM
rickseeman
Stuttgart, Arkansas
Can I order just the crank gear and setup kit. I need some parts too. I'll make some calls in the morning and see if parts are still available for these.
