Page 2 of 3 1 2 3
Re: who does cnc head porting ? [Re: pittsburghracer] #3041606
05/11/22 07:25 PM
05/11/22 07:25 PM
qc
mxbeep Offline OP
mxbeep  Offline OP
qc
thanks to all for the great information, i got a hold of KG earlier today and will be sending my heads over next week.
Re: who does cnc head porting ? [Re: mxbeep] #3041680
05/11/22 11:13 PM
05/11/22 11:13 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
Just an observation, cnc work does not make a head flow better unless the program copies somebodies good hand work. I have owned a flow bench for 25 years, I have fixed several cnc heads that did not work, I have seen several indy cnc heads that backed up, actually flowed less after .5 lift. air speed on the short side was too high. The ones you can't fix are too large of a port and the air speed is too slow. Ask a few questions before they hit the start button. And then there is the guys I know that when they got their cnc heads back they leaked water because of small pin holes in the casting where too much material was taken out. And then there are the cnc heads that are so thin the first time they get good and warm the valve seat starts to move and the valves won't seal correctly. Don't get me wrong I have seen some really good cnc heads but ask questions about port velocity and flow numbers to expect when they are finished.
Re: who does cnc head porting ? [Re: procharged 484] #3041685
05/11/22 11:40 PM
05/11/22 11:40 PM
yarnell,az
mopacltd Offline
mopacltd  Offline
yarnell,az
Wow, that reply is out of line!
Re: who does cnc head porting ? [Re: procharged 484] #3041686
05/11/22 11:44 PM
05/11/22 11:44 PM
napa ca
P
procharged 484 Offline
P
napa ca
I was hoping it might work and I would buy program but no go . The machine in question is used to manufacture medical parts for surgical tables , soon to get ISO cert for shop .
Re: who does cnc head porting ? [Re: mopacltd] #3041688
05/11/22 11:48 PM
05/11/22 11:48 PM
napa ca
P
P
napa ca
You think so ? he wasn't very friendly towards my statement . Ridicule begets same.
Re: who does cnc head porting ? [Re: jwb123] #3041742
05/12/22 09:49 AM
05/12/22 09:49 AM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Spot on!
CNC is only as good as what it is being told to do. The only way to get a good a good CNC program is to copy a hand ported port. If the hand ported port is garbage then the CNC program is garbage. And that even assumes that the hand ported port was probed/modeled correctly. And the CNC is stupid - it has no idea if the castings are thin anywhere.
I have a heavily ported set of 906 heads that were done by Batten years ago. That are major league cracked now. Someday when I have time, I plan on probing/modeling the bowl area and seeing what I can do with my 3 axis machine. But that will be me playing with my own stuff - not to do work for others.
Re: who does cnc head porting ? [Re: markz528] #3041755
05/12/22 10:58 AM
05/12/22 10:58 AM
an8sec70cuda Online content
an8sec70cuda  Online Content
Spot on!
iagree Exactly. The CNC machine is just the copier.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: who does cnc head porting ? [Re: mopacltd] #3041854
05/12/22 07:09 PM
05/12/22 07:09 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
How is it out of line??
Alan Jones
Re: who does cnc head porting ? [Re: an8sec70cuda] #3041958
05/13/22 09:58 AM
05/13/22 09:58 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
The cnc does the repetitious grunt work of making the ports the same....development is done by hand, requiring high levels of skill and experience/proper judgement. It all starts with someone's hand work being digitized.
Good luck to the OP with KG. Maybe Report back with flow sheet and pics if you can?
I've seen a few good running cars with their parts and decals on them, and there have been a few posts here about their work.
Rich H.
Esse Quam Videri
Re: who does cnc head porting ? [Re: ZIPPY] #3041965
05/13/22 10:42 AM
05/13/22 10:42 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
If you are smart you would ask for before and after flow numbers.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: who does cnc head porting ? [Re: pittsburghracer] #3042117
05/13/22 11:20 PM
05/13/22 11:20 PM
napa ca
P
P
napa ca
I see that you deleted my statement aimed at pittsnshyts . To get started he attacked me without any provocation f you for that and f him being a self-centered egotesticle . Ban me if you want at this point mopits is dying but I do enjoy it but not to extent of seeing the ban too used like in twitter
Re: who does cnc head porting ? [Re: procharged 484] #3042124
05/13/22 11:35 PM
05/13/22 11:35 PM
PA.
"Little"John
"Little"John
PA.
What the heck are you so upset about.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: who does cnc head porting ? [Re: pittsburghracer] #3042151
05/14/22 02:46 AM
05/14/22 02:46 AM
napa ca
P
P
napa ca
FORK YOU
Re: who does cnc head porting ? [Re: mxbeep] #3042265
05/14/22 02:06 PM
05/14/22 02:06 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
Dave (K&G) is a very nice guy. He has my engine right now.
If it helps at all, I have a pair of his cnc ported 906 heads. Have run them for years without issue.
He advertises that his cnc'd 906 heads flow 290 on the intake. Another well-known porter on this site told me that he flowed a K&G cnc'd 906 on his bench and confirmed that they flow as advertised.
Re: who does cnc head porting ? [Re: parksr5] #3042353
05/14/22 07:01 PM
05/14/22 07:01 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
All of the negative posts on CNC porting is why I suggested Scott Brown. I know he doesn't port heads but he knows the correct people that have good programs and has worked with them to improve the end product. I have had nothing but great results with his stuff.
Re: who does cnc head porting ? [Re: mxbeep] #3042441
05/15/22 07:16 AM
05/15/22 07:16 AM
Md.
carnut68 Offline
carnut68  Offline
Md.
Originally Posted by mxbeep
I need a set of Stealth heads ported, Hughes no longer does CNC porting, i wished Dwayne Porter could do them but he as well no longer offers the service, however he was kind enough to recommend me to KG engines, which i have been trying to get a hold for the last few months without any answer or replys from them.
Anyone know of a machine shop who offers CNC porting aside from the 3 mentioned?
thanks in advance
Why not have someone hand port them? Someone who knows what they're doing, someone who knows mopar?? Dwayne not doing any head porting? He did my Indy heads and I was happy with the performance improvement.
America First!
Re: who does cnc head porting ? [Re: pittsburghracer] #3042596
05/15/22 07:51 PM
05/15/22 07:51 PM
LA360 Offline
LA360  Offline
Some people think you just bolt a head down and flip the power on. Instant cnc’d head. Good luck with that.
Procharged 484, you were offended by this comment? I am trying to get my head around where the anger is coming from
Alan Jones
Re: who does cnc head porting ? [Re: LA360] #3042597
05/15/22 07:55 PM
05/15/22 07:55 PM
PA.
"Little"John
"Little"John
PA.
Yep that’s the one that launched him. Lol
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: who does cnc head porting ? [Re: mxbeep] #3042826
05/16/22 03:29 PM
05/16/22 03:29 PM
Southern California
BIG DRAG Offline
BIG DRAG  Offline
Southern California
Try Precision Cylinder Heads, Shane Studley has a new CNC machine and is doing lots of CNC heads.
714-401-7405
Re: who does cnc head porting ? [Re: pittsburghracer] #3042828
05/16/22 03:32 PM
05/16/22 03:32 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Weird! Thought maybe I missed something a a post had been deleted. shruggy
'63 Dodge 330
11.19 @ 121 mph
Page 2 of 3 1 2 3
