Re: It's alive
[Re: dvw]
#3041411
05/11/22 08:58 AM
05/11/22 08:58 AM
Posts: 11,722 Portage,michigan
B3422W5
Portage,michigan
Why did you move the cam? Calm down the launch?
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: It's alive
[Re: dvw]
#3041419
05/11/22 09:33 AM
05/11/22 09:33 AM
Posts: 855 Brisbane Australia
572B1
Brisbane Australia
Nearly a year after kicking a rod thru the pan. Parts hold ups. Welding the block, heads, and pan. A few upgrades that required fabrication. Fired up in a 1/2 revolution. Idle oil pressure is up with new lifter bore bushings. Crank scraper installed at .060" clearance. Cam backed up from 108 to 111. 5/8" studs in the axles. Fresh trans, shocks, slicks. Carbon hood is painted. Test on Friday. Doug looks great Doug. hope it runs well.
Re: It's alive
[Re: 572B1]
#3041421
05/11/22 09:48 AM
05/11/22 09:48 AM
Posts: 10,038 MN
JERICOGTX
MN
Looking forward to hearing the results Doug. Best of luck!
69 GTX
68 Road Runner
Re: It's alive
[Re: dvw]
#3041432
05/11/22 10:39 AM
05/11/22 10:39 AM
Posts: 17,887 S.E. Michigan
ZIPPY
S.E. Michigan
Looks exactly the same (perfect)! Welcome back.
Rich H.
Esse Quam Videri
Re: It's alive
[Re: ZIPPY]
#3041438
05/11/22 11:07 AM
05/11/22 11:07 AM
Posts: 1,552 Michigan
Kiddart
Awesome, looks killer as always!!!! cant wait to see you run
Thank you Kiddart
Re: It's alive
[Re: Kiddart]
#3041441
05/11/22 11:29 AM
05/11/22 11:29 AM
Posts: 1,146 Loudoun County, VA
Brad_Haak
Loudoun County, VA
What's the 411 on those carbs?
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: It's alive
[Re: GY3]
#3041460
05/11/22 12:22 PM
05/11/22 12:22 PM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
Re: It's alive
[Re: moparx]
#3041481
05/11/22 01:00 PM
05/11/22 01:00 PM
Posts: 2,515 PA
moparacer
PA
Great news! You car is a work of art.....
Interesting you retarded your cam too. I did a few weeks ago and it picked mine up.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
Re: It's alive
[Re: tboomer]
#3041564
05/11/22 04:39 PM
05/11/22 04:39 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
Nice job Doug!! The attention to detail on your car is amazing! ^^^ This ^^^ One of my favorite cars, period!
