Re: Brake fluid leaks
[Re: RROD]
#3041359
05/10/22 11:57 PM
05/10/22 11:57 PM
Posts: 43,244 Bend,OR USA
Cab_Burge
Tighten the heck out of them to get the flares to flatten out and seal Make sure and use a tubing wrench only on them, not an standard box or open end wrench Good luck, let us know what you find please.
[Re: RROD]
#3041480
05/11/22 12:56 PM
05/11/22 12:56 PM
Posts: 25,901 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Get a flare lapping tool.
[Re: John_Kunkel]
#3041495
05/11/22 01:22 PM
05/11/22 01:22 PM
Posts: 6,291 nowhere
Sniper
nowhere
Get a flare lapping tool. At $150 I'll just tighten and loosen a few times to seat the flare. https://www.speedwaymotors.com/Koul-Tools-P-51-Sure-Seat-Lapping-Tool-Kit-37-45-Degree-Flare,246739.html
[Re: fastmark]
#3041643
05/11/22 09:40 PM
05/11/22 09:40 PM
Posts: 15,451 Omaha Ne
TJP
Omaha Ne
I like to tighten them up and then back them off slightly and repeat that process several times, getting them tighter with each turn. And have used this procedure on MANY lines over the last 30+ years. Do not over tighten to the point of strippin the hex or threads. Good and tight but not brutally so. What you will observe if watching carefully, is that each time you tighten, loosen, and retighten with the same torque the Nut will move further than before. as it is forming the "SEAL" between the opposing flares. After repeating several times the nut will stop moving as much. The finishing tool John showed will likely help but I've never needed one. | Another tip if the leak continues, carefully look at the male and female flares. You'll likely see the "SEAL" problem normally on the softer of the two.
