Re: No turn signal or flashers
[Re: mercman1]
#3041029
05/09/22 06:02 PM
05/09/22 06:02 PM
Andrewh
[Re: BDW]
#3041111
05/10/22 12:01 AM
05/10/22 12:01 AM
Posts: 10,220 Someplace you aren't
SomeCarGuy
Don’t overlook the bulbs themselves. I had a funky deal, in my 69 GTX last week and it was the led bulbs I put in last fall. Internal short.
That’s kinda freaky you have two of the same cars like that.
I want my fair share
[Re: SomeCarGuy]
#3041123
05/10/22 06:46 AM
05/10/22 06:46 AM
Posts: 1,113 Usa
A39Coronet
Usa
That’s kinda freaky you have two of the same cars like that. LED turn signals require a matching LED flasher as well, correct?
[Re: A39Coronet]
#3041151
05/10/22 09:45 AM
05/10/22 09:45 AM
Posts: 16,150 Mesa, Arizona
dart4forte
Mesa, Arizona
That’s kinda freaky you have two of the same cars like that. LED turn signals require a matching LED flasher as well, correct? That would be my question as well
Abe Lincoln
[Re: mercman1]
#3041212
05/10/22 01:43 PM
05/10/22 01:43 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
The car in question is the street car in the right lane. When I restored it back in 98-99, I replaced every wire in the car with new harnesses from Year One. So the running lights and brake lights work. No turn signals or flashers.
Are the silver I think 3 prong flashers different for turn signals and flashers or are they interchangeable? Thanks to all. '69 Plymouth Service Manual shows the square two terminal flasher for the hazzards and another for the turn signals. The hazard fuse covers several circuits and is always hot. If the dome light works and the stop light works, then there's power to the fuse. The stop light circuit shares wire D31 from the Fuse to the connector fo the flasher unit. if the stop light works, power is getting that far. Turn signals only get power when the key is in Run or Accessory. They have no fuse. The flasher serves as circuit breaker. The places that both connect are the turn switch itself, and the turn switch connector. using a voltmeter you can check for power at the turn switch connector (steering column) and the hazzard connector.
[Re: Mattax]
#3041332
05/10/22 09:35 PM
05/10/22 09:35 PM
Posts: 15,434 Omaha Ne
TJP
Omaha Ne
Are the silver I think 3 prong flashers different for turn signals and flashers or are they interchangeable? Thanks to all. '69 Plymouth Service Manual shows the square two terminal flasher for the hazzards and another for the turn signals. The hazard fuse covers several circuits and is always hot. If the dome light works and the stop light works, then there's power to the fuse. The stop light circuit shares wire D31 from the Fuse to the connector fo the flasher unit. if the stop light works, power is getting that far. Turn signals only get power when the key is in Run or Accessory. They have no fuse. The flasher serves as circuit breaker. The places that both connect are the turn switch itself, and the turn switch connector. using a voltmeter you can check for power at the turn switch connector (steering column) and the hazzard connector. nice job mattax
[Re: A39Coronet]
#3041357
05/10/22 11:34 PM
05/10/22 11:34 PM
SomeCarGuy
That’s kinda freaky you have two of the same cars like that. LED turn signals require a matching LED flasher as well, correct? The ones I had were yorkim and didn’t require one. They flashed same as old school ones. Worked fine for awhile. Just more modern crap that isn’t made to last. They were awesome bright though. Three times more you could easily tell against the garage door looking back to back with old style. Wasn’t meant to be.
[Re: Cab_Burge]
#3041671
05/11/22 10:40 PM
05/11/22 10:40 PM
SomeCarGuy
Interesting side note is the company saw my review and contacted me today about making it right. Guess we’ll see what that means.
