Icon pistons #3040300
05/06/22 12:23 PM
05/06/22 12:23 PM
lancaster,california
johnnycuda Offline OP
Hey guys, I am building a 408 SBM for a 1938 Dodge truck, fun driver/street/strip kinda ride, ordered a set of Icon forged pistons from CNC Motorsports. I am just wondering if anyone has had any issues with this brand?, I have not used them, my last 3 engines had JE or Diamond pistons in the other cars. These are a pump gas, dished set, like 9.7 compression.
I should receive them Monday, shipping from KB. I remember hearing people having issues with the KB hypertectic pistons over the years.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: Icon pistons [Re: johnnycuda] #3040305
05/06/22 12:27 PM
05/06/22 12:27 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
I have used them in a few builds, No issues so far.
The only Carbs I care about are under the hood!
Re: Icon pistons [Re: johnnycuda] #3040307
05/06/22 12:29 PM
05/06/22 12:29 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i've been driving around on a set of icons for 6yrs. no issues; would buy again. i've been using kb hypers for 27yrs; again never an issue and would use again.
Re: Icon pistons [Re: lewtot184] #3040315
05/06/22 12:39 PM
05/06/22 12:39 PM
Thats good to hear, thanks guys, I don't have the time to go thru things again, looking at moving later this year.
Re: Icon pistons [Re: johnnycuda] #3040316
05/06/22 12:41 PM
05/06/22 12:41 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Great pistons...No issues. Used them for many years in various builds.
Re: Icon pistons [Re: Dragula] #3040323
05/06/22 01:09 PM
05/06/22 01:09 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
icon are forged...kb is hyper
Re: Icon pistons [Re: johnnycuda] #3040368
05/06/22 02:58 PM
05/06/22 02:58 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
That's because machinists would not follow the instructions about skirt clearance and ring gap,. They work fine if you use them properly and do not let the engine detonate.
The Icons are average nothing special good bang for the buck forged pistons that will work fine for most people. They would not likely be considered appropriate for a max effort engine.
Re: Icon pistons [Re: GomangoCuda] #3040371
05/06/22 03:40 PM
05/06/22 03:40 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
Have Icons in my stroker, they are fine.
Fixing to upgrade the top end on mine here before I get it out. Shortblock will stay. Icons, forged Scat crank and Scat H beam rods. I think all of this stuff can take more power than a stock block could handle.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Icon pistons [Re: johnnycuda] #3040491
05/07/22 02:11 AM
05/07/22 02:11 AM
I bought a set of their special race 572 C.I. B1 pistons for my next race B1 motor with 14.6 to1 compression and hoping to make 1000 + HP on E85 and add 150 to 500 HP of NOS. I was told by their tech guy they should live really well on the local 1/8-mile tracks using the NOS less than 6.0 seconds total WOT time using a set of Total Seal special NOS rings, hopefully race at WOT less than 5.0 seconds luck
Re: Icon pistons [Re: johnnycuda] #3040523
05/07/22 09:57 AM
05/07/22 09:57 AM
Andrews,In. U.S.of A.
67_Satellite Offline
Running them in my boosted 470. They'll take enough to blow out studded M.L.S.head gaskets (accidental over boost) and keep on going.753 grams piston& pin.
Re: Icon pistons [Re: johnnycuda] #3040576
05/07/22 02:13 PM
05/07/22 02:13 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
I have a set in my engine. They measure consistent everywhere. Good finish too. Hard to beat for the money. But DEF made south of the border. Heavy, but strong.
Re: Icon pistons [Re: GomangoCuda] #3040587
05/07/22 02:49 PM
05/07/22 02:49 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
I believe you're completely misinformed about ICON pistons. I have what you would consider a MAX effort small block Mopar with ICON pistons in it and they have performed flawlessly.
950hp
9000rpm
Re: Icon pistons [Re: Biginchmopar] #3040671
05/07/22 08:58 PM
05/07/22 08:58 PM
California
BigDaddy440 Offline
BigDaddy440  Offline
California
I dont think it's been mentioned, but Icon, KB, and Silvolite are all made by United Engine and Machine (UEM).
I have been using KB Hypers for 20 years and I always follow instructions for top ring gap. I've never had an issue.
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: Icon pistons [Re: Biginchmopar] #3040698
05/07/22 11:28 PM
05/07/22 11:28 PM
GomangoCuda Offline
GomangoCuda  Offline
That's because machinists would not follow the instructions about skirt clearance and ring gap,. They work fine i f you use them properly and do not let the engine detonate.
950hp
9000rpm
Can you order customs or are they shelf pistons? To me a MAX effort small block Mopar would be a no expense spared Comp eliminator or Australian Prostock type engine. Probably no Icons there. Your definition of MAX may be different.
Re: Icon pistons [Re: GomangoCuda] #3041035
05/09/22 06:40 PM
05/09/22 06:40 PM
Carson City, Nevada
Carson City, Nevada
950hp
9000rpm
Can you order customs or are they shelf pistons? To me a MAX effort small block Mopar would be a no expense spared Comp eliminator or Australian Pro Stock type engine. Probably no Icons there. Your definition of MAX may be different.
Lets go a set farther I know Jeff Lutz has been running ICON's in his GTO, is that a MAX effort deal or do you need it to be Top Fuel? As far as Comp Eliminator and what I have is not much different. I know a Pro Stock team that would not hesitate to run an ICON piston. You can order a custom, might take a while.
I don't understand why you want to bash or degrade ICON pistons, have you ever really looked at a set? If I were to list other companies such as JE, Diamond, Ross ect... are they OK in your book to be MAX effort?
Sounds to me like your just another key board racer.
Re: Icon pistons [Re: Biginchmopar] #3041043
05/09/22 07:21 PM
05/09/22 07:21 PM
Thanks for all the information guys, this motor is going in a 38 Dodge truck, probably Edelbrock RPMs, have a 8.75 for the rear, and we made a set of CalTracs and Split Monos for it instead using the 83 year old parts. I would imagine high 11s or low-12s depending on what gear I get for it, mostly a fun driver since tracks here are limited.....yes, Cali sucks.
Re: Icon pistons [Re: johnnycuda] #3041130
05/10/22 07:43 AM
05/10/22 07:43 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
So are you thinking about getting KB hyper or Icon forged?
Re: Icon pistons [Re: B1MAXX] #3041202
05/10/22 01:21 PM
05/10/22 01:21 PM
I wouldn't put a cast piston in a lawn mower down twocents
I've seen to many of them destroyed in the oil pan when a part failed, detonation and other failures or in a bunch of small piece after some small debris was ingested into the motors down shruggy
Re: Icon pistons [Re: B1MAXX] #3041292
05/10/22 07:16 PM
05/10/22 07:16 PM
I bought the Icon forged pistons, got them yesterday, look pretty nice, maybe a little heavier than the Diamond pistons in the 408 in my Valiant, but that is fine for what I am doing.
Re: Icon pistons [Re: johnnycuda] #3041396
05/11/22 07:48 AM
05/11/22 07:48 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Nice, I've used 2 sets of those. One was their FHR line which is cheaper version, and one set of their premium 2618. I think some on here don't know they make different forged lines. Comparing the FHR's to diamond really isn't the right comparison. The FHR is designed to be a good forged piston as cheap as possibe. Compare a premium series, now we are talking.
