stripped Holly squirter . How to fix? UPDATE #303939
04/30/09 05:31 PM
04/30/09 05:31 PM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline OP
VanishPt  Offline OP
V
Any suggestions on how to repair? I think it is a 12-28 screw. I have had no luck in finding a helicoil this size.
Re: stripped Holly squirter . How to fix? [Re: VanishPt] #303940
04/30/09 06:20 PM
04/30/09 06:20 PM
ohio
dart70 Offline
dart70  Offline
ohio
Re: stripped Holly squirter . How to fix? [Re: VanishPt] #303941
04/30/09 06:31 PM
04/30/09 06:31 PM
dip a nail in grease, put it in the hole where it goes, fill the gap with jb weld then drill and tap. or use titanium putty if you can find some. i did this on a chevy carb once. just tap it really really slow
Re: stripped Holly squirter . How to fix? #303942
05/01/09 07:21 AM
05/01/09 07:21 AM
V
VanishPt Offline OP
VanishPt  Offline OP
V
thanks for the info
Re: stripped Holly squirter . How to fix? UPDATE [Re: VanishPt] #303943
05/03/09 08:31 AM
05/03/09 08:31 AM
V
VanishPt Offline OP
VanishPt  Offline OP
V
I live about 30 miles from Carb Shop AED in Richmond. I got them to repair it. I was surprised at their method.
Hence the updated post.
They put a 12-24 ( not the 12-28 that it came with) helicoil in it. They said it was close enough and would work. "been doing it that way for years". You do have to use a hollow squirter screw.
It seems to work. You have to put a little extra effort getting the screw started , but it tightened right up.
Re: stripped Holly squirter . How to fix? UPDATE [Re: VanishPt] #303944
05/03/09 09:03 AM
05/03/09 09:03 AM
Virginia
JimG Offline
JimG  Offline
Virginia
Interesting.
After your first post, I looked looked around for 12-28 Helicoils and also came up empty handed. I had always assumed shooter therads were 12-24 like so many other threads on a Holley, never having stripped one and having the necessity of knowing.
Thanks for the update.
Re: stripped Holly squirter . How to fix? UPDATE [Re: JimG] #303945
05/03/09 12:30 PM
05/03/09 12:30 PM
V
VanishPt Offline OP
VanishPt  Offline OP
V
