Re: 1968 Roadrunner Proportioning Valves
[Re: dragon slayer]
#3037223
04/26/22 12:18 PM
04/26/22 12:18 PM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
What do you mean 2? An original 68 system (Bendix) would have the distribution block (common) and the single proportioning valve for the rear drums mid frame. The distribution block is the same whether the car has disc or drums , the second valve is a hold off valve.
