TCI RMVB #3036272
04/23/22 11:05 AM
04/23/22 11:05 AM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
TCI RMVB #1217 instructions say to remove the lower sealing ring in 1-2 accumulater , along with discarding the spring . Question is what is the purpose of removing the sealing ring and should a blocker rod be used , no mention of putting in blocker rod .
Re: TCI RMVB [Re: 426lloyd] #3036325
04/23/22 02:15 PM
04/23/22 02:15 PM
moparx Offline
moparx  Offline
here is a bump for ya. bump
perhaps John Kunkle or Transman will see this and get ya an answer.
those guys will know for sure.
beer
Re: TCI RMVB [Re: 426lloyd] #3036336
04/23/22 02:39 PM
04/23/22 02:39 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Removing the lower ring effectively deactivates the accumulator function...same as a blocker rod. This done, the spring serves no purpose.
Re: TCI RMVB [Re: John_Kunkel] #3036341
04/23/22 02:48 PM
04/23/22 02:48 PM
moparx Offline
moparx  Offline
i knew John would know the answer. up
beer
Re: TCI RMVB [Re: John_Kunkel] #3036349
04/23/22 03:03 PM
04/23/22 03:03 PM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
Thank you for the good info.
Re: TCI RMVB [Re: 426lloyd] #3036362
04/23/22 03:31 PM
04/23/22 03:31 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I usually put a blocker in it and leave the rings on. Even if it isn't needed. No springs, Force of habit. Maybe that's the wrong thing to do, but everything works fine.
