Help with spark plug heat range. #303561
04/30/09 08:51 AM
04/30/09 08:51 AM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
The T/A is running almost perfect but still needs a little tweeking. My ET is down to a 12.78 at 109.49 mph with a 60 foot of 2.02. The 2,8,1,7 plugs look awesome! The 4,6,3,5 plugs look a bit rich. It's a 6 pack set up and I'm thinking the distribution the manifold gives is what's giving the cylinders different amounts of fuel. Or is it one of the carbs doing it? The question is........... I'm running NGK5672A-8 plugs and was thinking about putting a hotter plug in the 4 holes that seem richer. Will this help anything or is mixing plugs tabboo?
Chris from New Jersey
Re: Help with spark plug heat range. [Re: fig426] #303562
04/30/09 11:56 AM
04/30/09 11:56 AM
When you say the plugs look good on some and fat on others is this based on cruise plug readings or on wide open throttle plug readings? If at cruise try opening the idle air bleed .003 to .006 on the bleed in the center carb. that feeds those cylinders. I would tell you which side but I don't have a 340 six pak intake to look at, sorry. To answer the main question you can run one step hotter plug to mask the problem and probally get away with it, but if the WOT is lean then your taking a chance of causing those four cylinders to go into detonation Let us know what you end up doing to solve that please
Re: Help with spark plug heat range. [Re: Cab_Burge] #303563
04/30/09 01:54 PM
04/30/09 01:54 PM
Swamps of South Jersey.
W
wildcargo Offline
wildcargo  Offline
W
I run the coldest plug that don't foul.
like Cab said you can run a hoter plug and mask the problum but it might go into detonation.
Bud www.wildcar-go.itgo.com
64 DODGE
60' 1.433,
1/8 6.38 at 107.4,
1/4 10.08 at 132.02
foot brake, leaf springs
Re: Help with spark plug heat range. [Re: wildcargo] #303564
04/30/09 02:06 PM
04/30/09 02:06 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
Listen to Cab. He knows what he is talking about. He helped me with my spark plug problems.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Help with spark plug heat range. [Re: 70sixpkrt] #303565
04/30/09 02:40 PM
04/30/09 02:40 PM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
Ok,,,, I'll play with the carbs some more and see what comes up. And to answer the question of when the plugs are checked,,, It is after a pass.
Re: Help with spark plug heat range. [Re: fig426] #303566
04/30/09 03:19 PM
04/30/09 03:19 PM
Q
Quicktree Offline
Quicktree  Offline
Q
are these new plugs your trying to read? if not your probably wasting your time. and whats telling you some are rich and some not? how are you reading them?
Re: Help with spark plug heat range. [Re: Quicktree] #303567
04/30/09 04:05 PM
04/30/09 04:05 PM
whats your compression?
-5672a-8 12-13.5 compression
if lower than that go 1 step hotter on your plug.5672a-7 9-11.5 compression
Re: Help with spark plug heat range. #303568
04/30/09 04:37 PM
04/30/09 04:37 PM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
Yes they are new when read, just after a pass. I'm reading them by the color around the porcelin and by the electrode. It's an eddy head 416 stroker with 12:1 compression.
Re: Help with spark plug heat range. [Re: fig426] #303569
04/30/09 05:29 PM
04/30/09 05:29 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Yes they are new when read, just after a pass. I'm reading them by the color of the porcelin and by the electrode. It's an eddy head 416 stroker with 12:1 compression.
no wonder, the porcelain has absolutly nothing to do with it being lean or rich. it could be bright white and still be rich. you read the base ring for carb tunning.
Re: Help with spark plug heat range. [Re: Quicktree] #303570
04/30/09 05:39 PM
04/30/09 05:39 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Re: Help with spark plug heat range. [Re: Quicktree] #303571
05/01/09 01:40 PM
05/01/09 01:40 PM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
Re: Help with spark plug heat range. [Re: fig426] #303572
05/01/09 02:45 PM
05/01/09 02:45 PM
NC
440Jim Offline
440Jim  Offline
NC
If it is 12.0, you should be able to run a hotter plug like the BCP7ES, BCPR7ES. The -8 should be fine too, but they are on the cold side for that CR.
Re: Help with spark plug heat range. [Re: 440Jim] #303573
05/01/09 02:52 PM
05/01/09 02:52 PM
thats what i would de for sure to clean up those plugs without an issue and to avoid detonation.
