what is a good temp range for a transmission - 1500 Ram #3035305
04/20/22 11:06 AM
04/20/22 11:06 AM
Cumming Georgia
cspracer Offline OP
cspracer  Offline OP
Cumming Georgia
I have a 2016 Ram 1500 5.7 with the A88HP70 transmission. It as just over 100K miles on it. I am towing a 24 foot trailer that weighs in at around 7200-7300 lbs. According to the chart I found, the max trailer weight rating for my configuration is 7780 lbs.
The truck tows this trailer fine, but I am concerned about long term impact to the transmission. I have a load balancing hitch, and I am looking at upgrading the trans cooler and possibly putting air bags on the truck. Of course the fuel mileage goes from 18 MPG to about 9 MPG, but I am ok with that as long as I am not putting the truck at significant risk. I always tow in Tow mode.
I only tow about 4-6 times per year and typically it is about a 200 mile round trip.
What is a good temp range for the transmission? I watch the temp while towing and see it ranges from 192-196. Is this too high?
What else should I do to the truck and or trailer to help preserve the health of the truck?
1968 - 383 Roadrunner 4 speed street car, Dad bought new
1970 - 440 Roadrunner drag footbrake car 6.99 1/8th
2016 - Hemi RAM 1500 - Hauls all the toys
North Georgia / Central NC
Re: what is a good temp range for a transmission - 1500 Ram [Re: cspracer] #3035332
04/20/22 12:48 PM
04/20/22 12:48 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
180-200 is ideal.
Re: what is a good temp range for a transmission - 1500 Ram [Re: John_Kunkel] #3035368
04/20/22 03:17 PM
04/20/22 03:17 PM
Cumming Georgia
cspracer Offline OP
cspracer  Offline OP
Cumming Georgia
So if I am running around 195 towing should I be concerned or is that normal?
Would adding a trans cooler be better or not? If it gets my temps down is that better or not, since I have read they are actually designed to get to 190 as quickly as possible as this is where they run best.
My truck recently had a ,message on the screen saying to have the transmission serviced and not to shift until I got home, however, at the shop they could not replicate it. They think I have a ground issue, but it scared me enough to consider adding an auxiliary cooler. These are actually fairly inexpensive ($100-$400 depending on style) compared to a new transmission!
Re: what is a good temp range for a transmission - 1500 Ram [Re: cspracer] #3037246
04/26/22 01:20 PM
04/26/22 01:20 PM
Which tranny fluid are you using in it and how often do you change it and the internal filter? work
as far as the tranny fluid temps most older vehicle that i have install a temp gauge in run to cold, shock below 160 F tsk
I like to see 160 to 250 F on a really hot summer day in the Mojave desert climbing the 17 mile long Baker grade going from 800 Ft above sea level to over 4400 Ft above sea level between L.A. and Las Vegas around 3:00 PM in August towing a 24 Ft enclose car trailer weighing around 8600 lbs. on the dual 5200 Lb.axles thumbs
Most non synthetic ATF have a dye in them that will start to turn from red to brown around 275F and will be black at or above 325 F scope
Once it turns black you need to have the tranny serviced with the filter and fluid changed and have the bands adjusted twocents wrench up
Re: what is a good temp range for a transmission - 1500 Ram [Re: Cab_Burge] #3037379
04/26/22 09:39 PM
04/26/22 09:39 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Pretty sure he’s referring to the ZF8HP70 trans that they tout as “fill for life” but in the fine print says 60k service if towing or extreme heat involved from ZF the manufacturer…. But Ram says “run it”. Btw it’s an expensive service.
Re: what is a good temp range for a transmission - 1500 Ram [Re: cspracer] #3037541
04/27/22 10:04 AM
04/27/22 10:04 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I have an 07 2500 5.9 with 315k on the original trans. Secret for hem living is a regular service that includes dropping the pan. The trans runs around 195 on a warm day. When Ipull my 24 ft enclosed with a load I average about 205 and pulling any of the grades around here it will get up to 220 fora short period of time. The truck warning light has never turned on.
Abe Lincoln
Re: what is a good temp range for a transmission - 1500 Ram [Re: J_BODY] #3037976
04/28/22 01:35 PM
04/28/22 01:35 PM
Cumming Georgia
cspracer Offline OP
cspracer  Offline OP
Cumming Georgia
That is correct, it is the ZF8HP70. No transmission dip stick. If does seem they do not want you to get inside of the trans, and it is expensive to service.
