Quest for 1000 hp, slow going!
#3034979
04/19/22 11:00 AM
04/19/22 11:00 AM
Posts: 9,996 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Mainly due to not getting parts, like intake valves, pistons. The new build is using the crower 4.315 stroke ccw crank i have had since 2005. It started life at 4.15 but was offset ground. I ordered 572-13 385cnc heads , pistons and valvetrain from Todd at Marsh Performance, along with a BME aluminum block in 4.500 bore. Todd has been great to work with, but like everybody else is waiting on parts. My heads are going to get a little extra TLC to add a few more cfm flow. The cam will be the same Mike Jones inverted radious cam that made 926 hp with 440-1 heads. The 3X intake got ported by Wilson manifolds, the compression will be as close to 15/1 as i can get, rings are .9mm(.036). Line2line skirt coating on the pistons, dlc coated .205 wall piston pins. Molnar 7.1 long rods, 2.2 rod bearings. I have a 4.5 inch vacuum pump pulley which will turn the pump as fast as suggested max. Terminater fuel injection, methanol fuel . I am hoping to see 1030 hp out of this deal, and my dart should weigh 2870 at the line. Hoping to run sub 8.50.
Re: Quest for 1000 hp, slow going!
[Re: gregsdart]
#3035012
04/19/22 12:18 PM
04/19/22 12:18 PM
Posts: 8,026 Tulsa OK
Bad340fish
Tulsa OK
Is the terminator EFI the throttle body system or port EFI? If it is a throttle body system do you have a carb to compare with it?
I hope you get your numbers!
68 Barracuda Formula S 340
[Re: 440Jim]
#3035069
04/19/22 03:38 PM
04/19/22 03:38 PM
Bad340fish
Tulsa OK
That 1000 hp level is tough in a typical normally aspirated engine. extra CID, vacuum pump, windage control, gas ported pistons, Wilson ported intake, etc.... These things all help.
I think you have a chance. Some engines make 930 others 1030 and they may not seem all that different in "specs".
Are you waiting on all those parts? Where do the heads and prep stand?
Terminator pic from Ronsfuel website. HA, I forgot about THAT Terminator Fuel Injection.....no need to have a carb on hand for comparison I am sure!
[Re: Bad340fish]
#3035074
04/19/22 03:56 PM
04/19/22 03:56 PM
gregsdart
I hope you get your numbers! thanks! The injection is constant flow mechanical. No electronics involved. This type of injection is dirt symple, pretty much. The pump is engine driven at camshaft speed, and pumps twice what the motor needs. Eight hoses to nozzles of . 038 size, and a nineth hose with a pill of . 080 to dump off the excess fuel. A tenth hose is set up to open at above peak torque as pressure rises, pushing through a spring loaded poppet valve with a small pill sized to keep the afr in range.
[Re: 440Jim]
#3035078
04/19/22 04:12 PM
04/19/22 04:12 PM
gregsdart
Terminator pic from Ronsfuel website. time will tell, right? Right now we are waiting on intake valves and pistons. Heads wrre cnc'd, then off to get some extra tlc.
[Re: gregsdart]
#3035084
04/19/22 04:27 PM
04/19/22 04:27 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
Good luck. Thing is gonna fly. Where are you getting weight off from?
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: gregsdart]
#3035141
04/19/22 08:29 PM
04/19/22 08:29 PM
Guitar Jones
Buddy of mine just had a 572 built at Best Machine. They wanted to build one of their cookie cutter engines with 1030 HP. 600-13 heads. He had them detune it, lower compression ratio, smaller cam, made 925.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#3035170
04/19/22 10:38 PM
04/19/22 10:38 PM
gregsdart
Buddy of mine just had a 572 built at Best Machine. They wanted to build one of their cookie cutter engines with 1030 HP. 600-13 heads. He had them detune it, lower compression ratio, smaller cam, made 925. Yep. I get that philosophy. But some of us just want to go faster. I have built some great bracket motors over the years. But, the itch to go faster has always been there.
[Re: gregsdart]
#3035176
04/19/22 11:01 PM
04/19/22 11:01 PM
B3422W5
Portage,michigan
Buddy of mine just had a 572 built at Best Machine. They wanted to build one of their cookie cutter engines with 1030 HP. 600-13 heads. He had them detune it, lower compression ratio, smaller cam, made 925. Yep. I get that philosophy. But some of us just want to go faster. I have built some great bracket motors over the years. But, the itch to go faster has always been there. Boost
[Re: B3422W5]
#3035286
04/20/22 10:28 AM
04/20/22 10:28 AM
Posts: 143 North America
kwikblownhemi
North America
Buddy of mine just had a 572 built at Best Machine. They wanted to build one of their cookie cutter engines with 1030 HP. 600-13 heads. He had them detune it, lower compression ratio, smaller cam, made 925. Yep. I get that philosophy. But some of us just want to go faster. I have built some great bracket motors over the years. But, the itch to go faster has always been there. Boost ^^^^
[Re: merpar]
#3035335
04/20/22 01:03 PM
04/20/22 01:03 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
Its certainly not impossible to get over 1000. Here is our pretty pedestrian 600-13 BBM out of our dragster, single 4bblunder 14-1compression and a smallish cam. Dynos are dynos, some are happy some are not. So FWIW the car has been 4.53 153 here in Las Vegas at 1920lbs with a 4.10 gear. We are in the middle of making it a bit more racey now with a couple points of compression and more aggressive camshaft. Will be posting results of that deal when and if we ever get the parts. Currently along with the redo of this one we are working on a new Predator bracket piece for my truck. Time will tell what it makes but we expect it to make over 1100.
[Re: gregsdart]
#3035707
04/21/22 01:40 PM
04/21/22 01:40 PM
Al_Alguire
Las Vegas
Al, i assume that was a 600 cube motor? Great powerband. I am guessing the Predater deal will be well above 1100. Yes this one is 622" the torque and where it all occurs certainly gives away the stroke, but this thing is very conservative on compression and camshaft. Also needs a much bigger carb.. But I have made more power at 525" with a B1MC, never scanned the sheet though. Again dynos are dynos but that car went 170 at 2975lbs. Did ET worth a poo as it was set up for stop racing. The Predator will likely make more power than this 600-13 piece at a lot less cubes. But it is a better head, similar internals on each, both built for bracket and stop racing.
[Re: Al_Alguire]
#3035811
04/21/22 07:20 PM
04/21/22 07:20 PM
gregsdart
Got a little more done today. Finished installing alL four brake calipers after draining the whole system. Finished installing the belt drive. The belt drive wasn't too tough, just a challenge to not hurt the upper seal for the cam. It has to slide over a key on the cam adapter and i hope it will relax because it did show a mark after installing and removing a couple times during mock up. After measuring all four open /close events, it came in at 110.5 on the intake and 117 exhaust. A half degree advanced at zero on the cam plate. Nice.
