HELP! '12 Durango front HVAC blower - on & off #3032755
04/11/22 09:44 PM
04/11/22 09:44 PM
My hovercraft is full of eels
DaveKanofsky Offline OP
UPDATE for ongoing problem - PLEASE send any ideas, and thanks to those who responded previously, I followed up on those leads and still have the problem.
2012 Durango front blower goes on and off when it is supposed to be on for the first ~15 minutes of vehicle operation, then stays on. It is not a touch screen control (base model with buttons and knobs). It does it at all blower speeds and HVAC settings. Smacking the dash/glove box area does nothing. The rear blower works fine.
Things I've done related to this:
- Removed TIPM looking for the burnt trace I've seen online on Ram's with similar issues, all looked good.
- Replaced front HVAC blower motor and fan
- Replaced Resistor
- Swapped dash control unit with junkyard part, so no guarantee here but behaved exactly the same
- Swapped the blower motor relay and J15 40-amp fuse in the TIPM with others
- Cleaned the ground #G911A under the console
I'M WILLING TO TRY JUST ABOUT ANYTHING, ALL HELP IS APPRECIATED!
BTW - yes I've changed the blend door gears, and it comes out in the correct area when it blows.
Thanks!
MOPARS ONLY!
'69 Daytona, '16 Plum Crazy Challenger, '12 Durango, '01 Sebring conv't
Chaplain, Racers For Christ (http://teamrfc.org/)
John 3:17
Re: '12 Durango front HVAC blower - goes on and off [Re: DaveKanofsky] #3035040
04/19/22 01:34 PM
04/19/22 01:34 PM
Somebody? Anybody?? Throw out a guess, I'll check it out
MOPARS ONLY!
John 3:17
Re: '12 Durango front HVAC blower - goes on and off [Re: DaveKanofsky] #3035045
04/19/22 01:48 PM
04/19/22 01:48 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
This won't make you feel any better, but here's for your reading pleasure: https://www.dodgedurango.net/threads/front-blower-motor-intermittently-not-working.74490/
Re: '12 Durango front HVAC blower - goes on and off [Re: Fat_Mike] #3035092
04/19/22 05:04 PM
04/19/22 05:04 PM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
These days everything goes thru a computer. My ex's 2015 Canyon had no AC. So she had my son ask me to look at it. For him, yes. Her? Pay the man.
Anyway, turns out the battery was iffy. Put my code scanner on it (hint number one for the OP) and it was telling me the HVAC computer was seeing low voltage (11.3V). So I did an engine off test of the battery voltage and it was about 12.2, which is low. Asked her about her recently driving to see if maybe the charging system didn't have time to top off the battery. It did, or should have, so I had her fire it up to measure the charging system output, 14.4, which was good. Then se says "hey the AC works" Me jut jamming my probe tips in between the battery post (no more side posts on GM's apparently) and the battery clamp made it work. Terminals weren't shiny, but there was no corrosion either. I suspect a good cleaning would have sufficed but the low voltage on the battery without the engine running made me suspect it was on the way out. It was a bit more than 3 years old and I had to replace the original at about that time frame too.
Near as I can figure the vehicle does a computer(s) system check before it turns on the charging system when you first fire it up and since the HVAC computer saw voltage below it's minimum it wouldn't turn on. I know it's a GM but I have seen similar issues on other late model cars caused by this. Heck my 86 Daytona had a problem where everything electrical BUT the engine would shut off. Be driving down the road, hit a bump, engine stayed running but the rest of the electrical system turned off. New battery fixed that.
Might check your battery voltage, engine off, and see what it says. Clean up the posts and terminals so they are shiny and see if that helps.
Re: '12 Durango front HVAC blower - goes on and off [Re: Sniper] #3184802
10/18/23 12:13 PM
10/18/23 12:13 PM
Still need help - please see updated post at top
MOPARS ONLY!
John 3:17
