Fender tag interior color on a 79 #3034710
04/18/22 02:57 PM
04/18/22 02:57 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
How to decode the tag (on radiator support) not like cars at all it seems. 1979 pickup
Re: Fender tag interior color on a 79 [Re: cudaman1969] #3034732
04/18/22 04:01 PM
04/18/22 04:01 PM
Middle TN.
4x4 Roundup Offline
4x4 Roundup  Offline
Middle TN.
Not like a car at all...very true. Rad. support tag indicates the exterior paint code(s). T.O.N. truck order #. Equipment details on a'79 truck are on the underhood Equipment Label and the Warren Truck Building Order found in various hidden places in the cab and even in the trans. crossmember underneath the Truck. Obviously, by now on a '79 truck most of underhood equip. labels and the buildsheets are missing. The window sticker is another source of information if available.
WANTED-- DEAD or ALIVE:
'70 Duster--- VS29H0B274908-----UPDATE---ENGINE BLOCK FOUND---Still looking for the B-5 car.
'79 Power Wagon W14JE9S137761 or 763
Re: Fender tag interior color on a 79 [Re: 4x4 Roundup] #3034738
04/18/22 04:06 PM
04/18/22 04:06 PM
fredericksburg,va
fredericksburg,va
Thanks for info, specifically looking for interior color.
Re: Fender tag interior color on a 79 [Re: cudaman1969] #3034850
04/18/22 09:27 PM
04/18/22 09:27 PM
Middle TN.
4x4 Roundup Offline
4x4 Roundup  Offline
Middle TN.
I checked one of my build sheets, trim color is indicated on line 6 FWIW. In a regular cab seats, dash plastic,& door panels, is about it, the rest is body color or satin black.
Are you looking for the vinyl or painted surfaces colors?
Re: Fender tag interior color on a 79 [Re: 4x4 Roundup] #3034884
04/18/22 11:28 PM
04/18/22 11:28 PM
fredericksburg,va
fredericksburg,va
Color of seats but I have no build sheet only the plate on radiator support and door jamb
Re: Fender tag interior color on a 79 [Re: cudaman1969] #3034936
04/19/22 08:31 AM
04/19/22 08:31 AM
Middle TN.
4x4 Roundup Offline
4x4 Roundup  Offline
Middle TN.
Are the door panels or any of the dash plastic there?
Re: Fender tag interior color on a 79 [Re: 4x4 Roundup] #3034961
04/19/22 10:14 AM
04/19/22 10:14 AM
fredericksburg,va
fredericksburg,va
Yes, dash is black, door panels, seat, carpet are tan. But all I’ve heard is Lil Reds only came with black or red interiors. If so someone went to a lot of trouble to change it out imo.
Re: Fender tag interior color on a 79 [Re: cudaman1969] #3035037
04/19/22 01:29 PM
04/19/22 01:29 PM
Middle TN.
4x4 Roundup Offline
4x4 Roundup  Offline
Middle TN.
So your saying it is a Little Red Express truck.
If that is so then yes, they were only black and red.
If it is a LRE truck the interior or the cab apparently has been changed.
Re: Fender tag interior color on a 79 [Re: 4x4 Roundup] #3035061
04/19/22 03:09 PM
04/19/22 03:09 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Or it's not a little red.
Re: Fender tag interior color on a 79 [Re: stumpy] #3035072
04/19/22 03:51 PM
04/19/22 03:51 PM
fredericksburg,va
fredericksburg,va
It is
Re: Fender tag interior color on a 79 [Re: cudaman1969] #3035103
04/19/22 06:41 PM
04/19/22 06:41 PM
5thAve Offline
5thAve  Offline
Chances are they left the original dash and changed the seats and carpet because they were junk.
Re: Fender tag interior color on a 79 [Re: 5thAve] #3035117
04/19/22 07:28 PM
04/19/22 07:28 PM
fredericksburg,va
fredericksburg,va
The reason I want to be 100% sure before changing anything, factory did crazy things to sell a truck back then
Re: Fender tag interior color on a 79 [Re: cudaman1969] #3035149
04/19/22 08:55 PM
04/19/22 08:55 PM
Middle TN.
4x4 Roundup Offline
4x4 Roundup  Offline
Middle TN.
My opinion...something like that on a LRE would be more likely to happen at the dealership but there is no way to know now without the paper documents. If you haven't already you might check with John Roberts over on the NALRETO facebook site.
John has a registry and might know of similar incidents.
