5/16 tubing bender for sharper turns #3033725
04/15/22 08:00 AM
04/15/22 08:00 AM
md
mopars4ever Offline OP
md
I have a tubing bender but I can`t get a real sharp close radius turn with it. My tool is not made for those type of turns. What inexpensive tool will make a tighter radius turn on 5/16 tubing? Will this one work? https://www.circlecsupply.com/gearw...igIWW9wIVhu6zCh2j1wjmEAQYASABEgK5XvD_BwE
It is hard to tell how big the 5/16 wheel is from the pic
Re: 5/16 tubing bender for sharper turns [Re: mopars4ever] #3033731
04/15/22 08:19 AM
04/15/22 08:19 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
maybe look into something like these from eastwood.
the one on the bottom of the 2 in the pic is available in a LOT of places. i think you can buy this at harbor freight.
if you are looking for a really tight bend the pliers type one in the top of the 2 pictured works pretty good. these are pretty hard to find.
https://www.eastwood.com/tubing-bender-and-forming-pliers-kit.html
perception is 90% of reality
Re: 5/16 tubing bender for sharper turns [Re: mopars4ever] #3033792
04/15/22 11:05 AM
04/15/22 11:05 AM
NW Illinois
MoonshineMattK Offline
NW Illinois
Swagelok benders are the best I've used. Try to find one on Ebay. Ridgid makes a knockoff that's not bad either
https://www.amazon.com/Ridgid-38038-Bender-605-608M/dp/B00AEA969W
Re: 5/16 tubing bender for sharper turns [Re: MoonshineMattK] #3033809
04/15/22 12:08 PM
04/15/22 12:08 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
the Swagelok/ rigid/ imperial eastman single size benders are the best overall. They are available as mentioned from several sources and the bay is a good place to find a used one. The one size fit's all Eastwood benders are junk IMO, they work but very limited. However the other "plier" style in the are handy for getting real close to the fitting. they also are available from multiple sources. Note there are newer versions of the pictured lever bender that offer a slight advantage when making S bends
Re: 5/16 tubing bender for sharper turns [Re: mopars4ever] #3033823
04/15/22 01:19 PM
04/15/22 01:19 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I've thought of packing the line with sand and screwing in two fine thread bolts in each end to contain it during the bending attempt. Then again, I've only used a high quality tubeing bender to bend my stuff.
Re: 5/16 tubing bender for sharper turns [Re: jbc426] #3033844
04/15/22 02:56 PM
04/15/22 02:56 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Is this a tight enough radius?
https://ecihotrodbrakes.com/index.html
Kevin
Re: 5/16 tubing bender for sharper turns [Re: Twostick] #3033847
04/15/22 03:22 PM
04/15/22 03:22 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I like that one. I've used a few, best I've bought so far is one that's like the blue Eastwood bender.
Main thing of course is proper support for the inside radius so it doesn't kink.
Re: 5/16 tubing bender for sharper turns [Re: Twostick] #3033914
04/15/22 07:16 PM
04/15/22 07:16 PM
md
md
Kevin
yes that will work until I saw the price.
Re: 5/16 tubing bender for sharper turns [Re: Twostick] #3033925
04/15/22 08:00 PM
04/15/22 08:00 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Kevin
It doesn't do 5/16"
Doug
Re: 5/16 tubing bender for sharper turns [Re: dvw] #3033969
04/15/22 10:12 PM
04/15/22 10:12 PM
5thAve Offline
5thAve  Offline
I have these tube benders and have also done tight bends wrapping the line around a socket.
Re: 5/16 tubing bender for sharper turns [Re: dvw] #3034000
04/16/22 12:15 AM
04/16/22 12:15 AM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Kevin
It doesn't do 5/16"
Doug
The 4 in 1 model does. Not cheap but good tools seldom are.
Kevin
Re: 5/16 tubing bender for sharper turns [Re: Twostick] #3034229
04/16/22 08:11 PM
04/16/22 08:11 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
I'm looking into this
Re: 5/16 tubing bender for sharper turns [Re: A990] #3034260
04/16/22 09:49 PM
04/16/22 09:49 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
What I do is get a rubber cap for both ends of the tube. Fill it with water and freeze it overnight. Then bend it as you want. The water acts as a mandrel.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: 5/16 tubing bender for sharper turns [Re: FurryStump] #3034379
04/17/22 12:52 PM
04/17/22 12:52 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
HMM, I've heard of using sand in exhaust tubing to prevent it from collapsing but not a good ised on small tubinf for furel / brake lines etc.
Wonder if something like baking soda or other rinseable material would work ? shruggy
Re: 5/16 tubing bender for sharper turns [Re: Twostick] #3034399
04/17/22 01:41 PM
04/17/22 01:41 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Kevin
I like that! I think I will make me some, but I like one size at a time.
I made this bender for bending 5/16" brake line on my buddy's 65 Dodge RV.
Re: 5/16 tubing bender for sharper turns [Re: mopars4ever] #3034756
04/18/22 04:49 PM
04/18/22 04:49 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
