Re: Firecore RTR distributor results inside [Re: Bob_Coomer] #1221891
04/25/12 03:28 PM
04/25/12 03:28 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Hi Bob. According to this chart, and my test at Norwalk, our CD Coil will power the 7AL and 7AL Plus. Thanks for asking.
http://www.msdignition.com/products/coils/
As said in a ton of threads, ignition wires do not magically "make" power. They do, however, allow the engine to reach it's potential horsepower. When comparing ignition wires, its the same as everything else. Apples to apples. You can not compare, fairly, two different type wires. For example, carbon core and spiral core. Two different animals. Where our wires shine is on the extreme engines. Yes a 250 horse engine will notice a difference when switching from lower-performance wires...but when dyno-testing hi-level ignition wires, it will be hard for the average data aquisition dyno operator to see a difference. This being said, I am not sure how Greg Stanfield(NitroFish Pro Stock car) dynoed, but he saw an absolute difference, and will not be taking his Firecore50 Wires off. Same goes true with Tony Shoe, Antron, Spencer, Cruz, Hagan, Beckman, Gray, McMillan, both Al Anabi T/F dragsters, and a couple others.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Firecore RTR distributor results inside [Re: sunroofgtx] #1221892
04/25/12 09:05 PM
04/25/12 09:05 PM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
Keith, have you done a test with Ricks billet distributor (not the one with ignition module) compared to an MSD Pro Billet? I bought one of these from Bob George over the winter and ran it on the dyno in my new 540. We locked out the timing and used the engine shop's MSD 6-al and my MSD HVC coil. I am quite pleased with the results but did not have another distributor to compare it to.
Randy
Re: Firecore RTR distributor results inside [Re: Dartin] #1221893
04/25/12 09:35 PM
04/25/12 09:35 PM
Niles, Michigan
Hitman340 Offline
Hitman340  Offline
Niles, Michigan
Good info as always Keith.I hope everyone rewalizes how much money they can save by all the info you provide for free.
And it looks like they can make some dependable HP increases by buying Ricks Firecore products.
Thank you Keith.
Re: Firecore RTR distributor results inside [Re: Hitman340] #1221894
04/25/12 09:53 PM
04/25/12 09:53 PM
central ohio
N
nss guy Online happy
nss guy  Online Happy
N
central ohio
I've been running the race distrutor and coil for the last 2 yrs. Excellent product!!
Several of my friends run the msd dizzy and they always seem to end up with corrision or rust under the cap?? None what so ever with Firecore
Re: Firecore RTR distributor results inside [Re: Dartin] #1221895
04/25/12 10:06 PM
04/25/12 10:06 PM
Northern Indiana
Dunnuck Racing Offline OP
Northern Indiana
Randy,
I talked to Rich from Firecore about a few other things I might test with his products,but I have not called him back yet. Maybe I should try his regular distributor against an MP? I am not sure how the pick up coil in his is set up,but I know the MP and MSD have a different signal from each other.
It makes a difference with some ignitions,and nothing noticeable on others.
Jeff,thanks for the kind words!!
Keith
Re: Firecore RTR distributor results inside [Re: Dunnuck Racing] #1221896
04/25/12 10:21 PM
04/25/12 10:21 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
This is just my opinion, but I believe there is no HP made by a distributor. All it does is direct voltage to the plugs.
HOWEVER, where it really makes a difference, is that the Firecore Distributor timing remains exact and steady to 10,000 rmp. Dead nuts, zero retard. No other top-mount distributor in the industry can advertise that. Also, the Firecore Distributor is the only hot-forged billet piece in the industry. Thanks guys.
Re: Firecore RTR distributor results inside [Re: sunroofgtx] #1221897
04/25/12 10:28 PM
04/25/12 10:28 PM
Northern Indiana
Northern Indiana
Rich,I agree with your statement for the most part.
The only thing I have seen with them is a couple of situations where an ignition system was not happy with the signal the pick up coil was putting out.
The MP distributors and stock replacements use a low resistance pick up coil,the MSD uses a higher resistance one. I have seen a distributor change totally screw with what is going on with an ignitions signal. That is why I wondered how yours compared.
Keith
Re: Firecore RTR distributor results inside [Re: sunroofgtx] #1221898
04/25/12 10:34 PM
04/25/12 10:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Rich... is your coil with a 7AL considered a street
set up.... thanks for the info Keith ... I'll be
ordering up some parts shortly for both the race car
and my Rampage
Re: Firecore RTR distributor results inside [Re: MR_P_BODY] #1221899
04/26/12 09:30 PM
04/26/12 09:30 PM
Northern Indiana
Northern Indiana
I retested with the Firecore coil and the MSD 6 today and it ran great. Not sure what happened the other day. Never missed a beat,ran pretty even with the MSD coil.
I did not think to print out anything,as there really was no huge improvement or loss to show. But at least it is nice to know it runs well. The one thing better about the Firecore coil I noticed was that the engine seems to repeat better from pull to pull with it compared to the MSD. That would have to be better for consistency in my opinion.
Keith
Re: Firecore RTR distributor results inside [Re: Dunnuck Racing] #1221900
04/26/12 11:10 PM
04/26/12 11:10 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Thank you, Keith. If you want, I'll send you a mechanical and a BRAND-NEW MSD Billet. You can "play" with those if you like.
We said from the beginning, Firecore Performance Products are a proven-quality product. This info is advantageous for engine builders and racers alike.
Keith, welcome to the Firecore Performance Products authorized dealer network.
Re: Firecore RTR distributor results inside [Re: Dunnuck Racing] #1221901
04/27/12 02:41 PM
04/27/12 02:41 PM
fullmetaljacket Offline
Firecore Mechanical Distributor, Firecore coil and Firecore wires here. Smooth sailing so far.
Re: Firecore RTR distributor results inside [Re: Dunnuck Racing] #1221902
04/28/12 02:35 PM
04/28/12 02:35 PM
Northern Indiana
Northern Indiana
I forgot to post this up last night,it was a long day here.
I ran the MP orange and chrome box with several differetn coils. The best of those pulls compared to the RTR and matching Firecore coil are here. I can get the MP boxes to make about the same power up top,but all through the middle they are weaker.
I should also tell you that this is the better of two orange boxes I have,it is a pretty old one. It consistently out performs the chrome one with each coil I tried at this level.
Keith
Re: Firecore RTR distributor results inside [Re: Dunnuck Racing] #2959368
08/31/21 10:19 AM
08/31/21 10:19 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Old Thread
I was trying to get ahold of Dunnick Racing and Firecore Distr (Either busy , or don’t post anymore ?) About there RTR Distributors , if still available ?
Also Dunnick Racing , his pictures expired on this thread , when testing
Wanted to see if anyone saved his results on testing coils and Mopar ignition boxes when it came to RPMs and dwell variation versus the RTR Distributor
Thanx Scott
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Firecore RTR distributor results inside [Re: Dunnuck Racing] #2960512
09/03/21 04:15 AM
09/03/21 04:15 AM
eastern,Ky
70RT Charger Offline
eastern,Ky
Keith
Have you ever tried the Rev N Nator box?
Re: Firecore RTR distributor results inside [Re: sunroofgtx] #2960570
09/03/21 10:31 AM
09/03/21 10:31 AM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Originally Posted by sunroofgtx
Thanks for the posts and info, Keith. Something must be wrong with the coil. We made that coil specifically for the MSD 6 al AND our RTR Distributor. It has the identical specs as the MSD SS Coil. Please check again. If it does not work, I'll send another. I have been running our coil and the MSD6AL for 2 years on my 10.81 Hemi Purple Behemouth. <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
<img src="/ubbthreads/images/graemlins/drive.gif" alt="" />
Thanks again.
Been running one with my 6al since 2015. Never a problem.
Ok
Re: Firecore RTR distributor results inside [Re: cudatom] #3033830
04/15/22 01:39 PM
04/15/22 01:39 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Hey guys, I am back!!! I felt wierd still going as SunroofGTX, without actually owning a SunroofGTX. Well, happily, I re-own my original SunroofGTX!! We have a brand new, new and improved RTR Distributor. Better in every respect. I will post pics next week, but it takes the screw down style, msd style male distributor cap.. We private label them for Summit.
Re: Firecore RTR distributor results inside [Re: Dunnuck Racing] #3033902
04/15/22 06:50 PM
04/15/22 06:50 PM
i could not see any of your files posted on here, I wonder why shruggy
I would really like to see the results luck
Re: Firecore RTR distributor results inside [Re: Cab_Burge] #3034602
04/18/22 09:14 AM
04/18/22 09:14 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Previously a lot of folks on here had complaints about the Firecore distributors - mainly quality if I recall. I had one but never ran it - I sure didn't see any quality issues. Sold it 'cause I'm going to need a dual-sync. Your tests seem to have proven them wrong. I'd like to see Rich make a dual-sync !!
Re: Firecore RTR distributor results inside [Re: Stanton] #3159483
07/13/23 09:51 PM
07/13/23 09:51 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
