Faria Tachometer
#3032842
04/12/22 10:18 AM
04/12/22 10:18 AM
Posts: 10,713 North Dakota
6PakBee
North Dakota
Does anyone know if a Faria current triggered tach (tach wired in series with the coil on a point ignition) will work with the Chrysler electronic ignition?
Re: Faria Tachometer
[Re: 6PakBee]
#3033019
04/12/22 09:32 PM
04/12/22 09:32 PM
Posts: 15,350 Omaha Ne
TJP
Omaha Ne
Some info here LINKYmight try GOOGLING I do know that a commonly sold electronic ignition adapter for a Sun distributor machine is nothing more than an HEI module in an overpriced black box DAMHIK (butthurt)
[Re: TJP]
#3033076
04/13/22 08:54 AM
04/13/22 08:54 AM
6PakBee
North Dakota
Some info here LINKYmight try GOOGLING I do know that a commonly sold electronic ignition adapter for a Sun distributor machine is nothing more than an HEI module in an overpriced black box DAMHIK (butthurt) Some info here? Let's see, MSD, HEI, Petronics Flame Thrower III & Igniter III....maybe I missed it but I didn't see anything about a Mopar electronic ignition on this AMC board..... and this is a Mopar board. But maybe I'd have better luck asking this question on an International Harvester forum. What do you think about that?
[Re: 6PakBee]
#3033163
04/13/22 01:49 PM
04/13/22 01:49 PM
TJP
Omaha Ne
Some info here LINKYmight try GOOGLING I do know that a commonly sold electronic ignition adapter for a Sun distributor machine is nothing more than an HEI module in an overpriced black box DAMHIK (butthurt) Some info here? Let's see, MSD, HEI, Petronics Flame Thrower III & Igniter III....maybe I missed it but I didn't see anything about a Mopar electronic ignition on this AMC board..... and this is a Mopar board. But maybe I'd have better luck asking this question on an International Harvester forum. What do you think about that? OK, I'll refrain from trying to help you in the future What do YOU think about that ? BTW there was a bit of info in there that you blew right by
[Re: TJP]
#3033441
04/14/22 09:29 AM
04/14/22 09:29 AM
6PakBee
North Dakota
Some info here LINKYmight try GOOGLING I do know that a commonly sold electronic ignition adapter for a Sun distributor machine is nothing more than an HEI module in an overpriced black box DAMHIK (butthurt) Some info here? Let's see, MSD, HEI, Petronics Flame Thrower III & Igniter III....maybe I missed it but I didn't see anything about a Mopar electronic ignition on this AMC board..... and this is a Mopar board. But maybe I'd have better luck asking this question on an International Harvester forum. What do you think about that? OK, I'll refrain from trying to help you in the future What do YOU think about that ? BTW there was a bit of info in there that you blew right by Knock yourself out. Being a smarta@@ with "might try GOOGLING" is help? With the kind of help you provided I am no further ahead than I was before you "helped". So please, carry on.
[Re: TJP]
#3033513
04/14/22 12:46 PM
04/14/22 12:46 PM
6PakBee
North Dakota
Knock yourself out. Being a smarta@@ with "might try GOOGLING" is help? With the kind of help you provided I am no further ahead than I was before you "helped". So please, carry on. Wasn't tryin to be a smart --- but rather helpful. I don't have the time to do all the research required to solve your issue. But others have faced it and it appears solvable with effort and research. hence my comment on the sun adapter But your firing back in the manner you did really was uncalled for. Good luck with your dilemma Really? When someone sarcastically comments "might try GOOGLING", I'm supposed to just let that go? If you didn't know the answer to a question you have three choices 1) say nothing, 2) say you can't help, 3) relay what you do know about the subject that may be of value. But "might try GOOGLING", with Google in all caps, fits into none of the three.
[Re: 6PakBee]
#3033672
04/14/22 10:04 PM
04/14/22 10:04 PM
TJP
Omaha Ne
Knock yourself out. Being a smarta@@ with "might try GOOGLING" is help? With the kind of help you provided I am no further ahead than I was before you "helped". So please, carry on. Wasn't tryin to be a smart --- but rather helpful. I don't have the time to do all the research required to solve your issue. But others have faced it and it appears solvable with effort and research. hence my comment on the sun adapter But your firing back in the manner you did really was uncalled for. Good luck with your dilemma Really? When someone sarcastically comments "might try GOOGLING", I'm supposed to just let that go? If you didn't know the answer to a question you have three choices 1) say nothing, 2) say you can't help, 3) relay what you do know about the subject that may be of value. But "might try GOOGLING", with Google in all caps, fits into none of the three. you seem to be fixed on the "might try GOOGLING" comment blowing by my #3 comments I do know that a commonly sold electronic ignition adapter for a Sun distributor machine is nothing more than an HEI module in an overpriced black box And the forum I directed you to did have commentary on the problem you'll likely be facing. I found that by GOOGLING Faria tachometers. It's simple and if you spent as much time GOOGLING the subjetc as you have trying to slam me on the GOOGLING comment you'd likely be further ahead. If you had said you needed further help understanding the electrical part I would've been more than happy to help, but that's not the case sorry you took it as offensive, your issues, not mine
[Re: Moparite]
#3033733
04/15/22 08:35 AM
04/15/22 08:35 AM
6PakBee
North Dakota
I never heard of a "Faria Tachometer" so googled it. Then googled it for the wiring and found this. Looks like it should work and googling is not a bad thing but i would look up the manufactures info first. That's just me and my $.02 Thanks for some real help. The situation with current actuated tachs is that they depend on the current waveform through the primary lead to the coil. They have few active components in their circuitry, they are basically current transformers with an RC/zener circuit to clip and modify the output into an analog voltage that feeds the meter movement. I know what the waveform for a points ignition looks like but I cannot find what the waveform is for the supply to a Mopar electronic ignition. And I haven't found it after hours of GOOGLING it. The HEI adapter seems to be the best bet at this point.
[Re: TC@HP2]
#3033921
04/15/22 07:52 PM
04/15/22 07:52 PM
6PakBee
North Dakota
Faria is commonly found in marine applications, but they make a lot of instruments for other stuff too.. They still exist and still make a crap load of dash gauges. They also offer a rebuild service to recondition older gauges. They have a whole link of technical tuff on their site, including phone numbers. https://fariabeede.com/2-pages/home.php Thank you.
[Re: 6PakBee]
#3034040
04/16/22 08:24 AM
04/16/22 08:24 AM
Posts: 6,241 nowhere
Sniper
nowhere
I googled it, well actually DDG. First link listed had your waeform. https://www.forabodiesonly.com/mopa...-pickup-polarity-and-rotor-phase.441771/Might try honing your googlefu. Phrase I used was "mopar electronic ignition waveform"
[Re: Sniper]
#3034043
04/16/22 08:39 AM
04/16/22 08:39 AM
6PakBee
North Dakota
I googled it, well actually DDG. First link listed had your waeform. https://www.forabodiesonly.com/mopa...-pickup-polarity-and-rotor-phase.441771/Might try honing your googlefu. Phrase I used was "mopar electronic ignition waveform" I think at this point . Thanks for the help but I already found that. What that covers is the waveform from the distributor pickup, not the waveform in the coil circuit. So while it's interesting, it's not the answer. So I would prefer this thread end now. I'll figure something out.
[Re: Mattax]
#3034313
04/17/22 08:29 AM
04/17/22 08:29 AM
6PakBee
North Dakota
Those are waveforms showing the secondary voltage.
Current for the tach will be on the coil's primary wiring. I beleive my description of the primary side waveform is essentially correct. Sorry, I missed your post, got lost in all the noise. Well, you can't hurt one of those tachs unless you pass full voltage to ground through it so if my project comes to pass I'll give it a whirl.
[Re: Mattax]
#3034317
04/17/22 08:52 AM
04/17/22 08:52 AM
Sniper
nowhere
Current for the tach will be on the coil's primary wiring. I beleive my description of the primary side waveform is essentially correct. Maybe the OP can google a cheap USB oscope and sort it out himself.
