"Stock type" clutch #3032243
04/09/22 11:21 PM
04/09/22 11:21 PM
Washington
hemienvy Online content OP
hemienvy  Online Content OP
Washington
Here's the question, is it common for a shop to rebuild your clutch cover ?
Or does everyone just buy new ? Seems like a rebuild might be cheaper.
This is not anything too special, mild 432-inch / 4-speed / 3.91 sure grip.
Would they just resurface the pressure plate and maybe put in new springs ?
Re: "Stock type" clutch [Re: hemienvy] #3032255
04/10/22 05:02 AM
04/10/22 05:02 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I had a few rebuilt by a local company and they were not that good. I would send it off to Ram clutches. They still make the Borg and Beck style. I don’t care for the diaphragm style as they ratio is wrong for the Mopar linkage. I’m sure some here knows of more sources.
Re: "Stock type" clutch [Re: fastmark] #3032263
04/10/22 07:37 AM
04/10/22 07:37 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
back when i was running 4spds rebuilding pressure plates was common. more of a borg&beck/long type thing. rebuilding diaphragms was not common but possible.
Re: "Stock type" clutch [Re: lewtot184] #3032314
04/10/22 12:12 PM
04/10/22 12:12 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
I tried to get one done a few weeks ago at the place that did them before and they will no longer do it. They still have everything, the jig to set finger height with mics and everything, but they just sell new now.
Re: "Stock type" clutch [Re: 4406bbl] #3032378
04/10/22 04:36 PM
04/10/22 04:36 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Did a google search & found Fort Wayne Clutch & Driveline 800-258-8243,also Clutch & Brake of Asheville 828-252-6470.
Re: "Stock type" clutch [Re: 71GTX471] #3032414
04/10/22 07:04 PM
04/10/22 07:04 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
Since Mcleod doesn't make the Borg and Beck anymore, I had them rebuild my pressure plate. I also sent them my flywheel and they balanced it to the pressure plate. So far so good. Send it to Mcleod so they can rebuild it.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: "Stock type" clutch [Re: 70sixpkrt] #3032429
04/10/22 07:49 PM
04/10/22 07:49 PM
Washington
Washington
Hmmm, interesting, I didn't think it would get to the point where B&B is not common.
Maybe I should have saved all those B&B covers !
70 Sixpack, how much did Mcleod charge ?
Re: "Stock type" clutch [Re: 4406bbl] #3032464
04/10/22 09:17 PM
04/10/22 09:17 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Did you try Lincoln Clutch and brake ?
Myself I love Centerforce clutches a lot less stress on the linkage frame side mount etc. We have installed a butt load of them in the last 20+ years with only one issue which was a mismatched PP and disc. twocents beer
Re: "Stock type" clutch [Re: TJP] #3032477
04/10/22 09:39 PM
04/10/22 09:39 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Myself I love Centerforce clutches a lot less stress on the linkage frame side mount etc. We have installed a butt load of them in the last 2 years with only one issue which was a mismatched PP and disc. twocents beer
No, I was just being lazy I can do it myelf in a press and using a valve spring compressor, but just wanted to pay someone as their setup could give me pressure and set the height in minutes, I wanted to use up what I have as it is a new mopar green with the good eyebolts.
As others have said the centerforce just feels wrong, like the timing is off in the 10.95 application for lack of a better term. The dual friction 10.5 works pretty nice. Tempting for sure for the leg as I get older.
Re: "Stock type" clutch [Re: hemienvy] #3032482
04/10/22 09:46 PM
04/10/22 09:46 PM
70sixpkrt Offline
70sixpkrt  Offline
$75 to rebuild it and $125 to balance flywheel to the pressure plate.
4-speed
3:54 Dana
Re: "Stock type" clutch [Re: 70sixpkrt] #3032495
04/10/22 10:20 PM
04/10/22 10:20 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
What a deal!!!
Re: "Stock type" clutch [Re: hemienvy] #3032504
04/11/22 03:33 AM
04/11/22 03:33 AM
Armenia
mohvh Offline
mohvh  Offline
Armenia
I know that rebuilding is cheaper, but I think buying a new one is a better choice.
Always use your chance!
Electromagnetic Tooth Clutches
Re: "Stock type" clutch [Re: mohvh] #3032563
04/11/22 11:16 AM
04/11/22 11:16 AM
VA
dragon slayer Offline
VA
I have taken several apart as I investigate orig clutches and pressure plates. With the clutch press which I had available, taking apart is not hard. You will probably find it may have been rebuit before, or the plate may be in poor shape.
Beware there were Heavy duty housing, levers and eyebolts. Thicker metal and larger eye bolts. Also there were high grade pressure plate. Most likely they will be warped and possibly bad heat spots. If warped significantly not worth having it machined. The plate may also be thin from a prior rebuilt.
You can test springs like valve springs and early service manual has the spring spec. Make sure you document how it comes apart.
Look for cracks in levers, worn pins, eyelets, pressure plate, etc...
I had 2 plates redone for Hemi specific 101/2" housing. Have reenforced plates for the rollers. It was a fun exercise, but I would not put it in a drag car.
20201120_151552_resized.jpg20201120_151652_resized.jpg20201211_162417.jpg20201120_151638_resized.jpg
Re: "Stock type" clutch [Re: dragon slayer] #3032579
04/11/22 12:12 PM
04/11/22 12:12 PM
Washington
Washington
Dragonslayer, Thanks for that.
Good and interesting points. I'll take a closer look at this used cover I've got.
Re: "Stock type" clutch [Re: mohvh] #3032590
04/11/22 12:34 PM
04/11/22 12:34 PM
70sixpkrt Offline
70sixpkrt  Offline
I agree but Mcleod doesn't make my Borg and Beck pressure plate (360153) any more.
4-speed
3:54 Dana
Re: "Stock type" clutch [Re: 70sixpkrt] #3032638
04/11/22 03:18 PM
04/11/22 03:18 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Ram and others still have them in normal and competition grade, but I have no idea if the roller assist is there if you want new stuff.
Re: "Stock type" clutch [Re: 4406bbl] #3033111
04/13/22 11:46 AM
04/13/22 11:46 AM
Washington
Washington
Evidently there's a place in Eugene Oregon that rebuilds them, but I don't have a name.
Anyone know ?
Re: "Stock type" clutch [Re: hemienvy] #3033602
04/14/22 04:16 PM
04/14/22 04:16 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
https://www.rochesterclutch.com/
Talk to Sammy - he speaks mopar.
Do it correctly
Get a custom clutch from RCB - you can specify how heavy a clutch pedal you want. 2800lbs would be fine for your application and easy on you
buy the 6 paddle disc with the metallic pucks and never look back- the only caveat is the bell house needs to be dialed in very close to 0.0000
I have used RCB clutches - nothing better
sogtx has one of RCB's clutches with the 6 paddle disc behind a alum head 505 6 pak [A12 car] attached to a passon 5 sp with 4:10s...ask him
