Rocker pushrod adjusters? #3031177
04/06/22 10:47 AM
04/06/22 10:47 AM
N/E, Michigan
RATTRAP Offline OP
RATTRAP  Offline OP
N/E, Michigan
Through oiling, side oiling, or no oiling. shruggy
Re: Rocker pushrod adjusters? [Re: RATTRAP] #3031208
04/06/22 12:06 PM
04/06/22 12:06 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Are you asking for brand or configuration recommendation? Post makes no sense... confused
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Rocker pushrod adjusters? [Re: RATTRAP] #3031222
04/06/22 12:21 PM
04/06/22 12:21 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
I use with great success Manton through hole PR adjusters. stopped my cup/ball gauling issue part number 824 IIRC yoru part # may be different
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Rocker pushrod adjusters? [Re: Brad_Haak] #3031247
04/06/22 01:26 PM
04/06/22 01:26 PM
N/E, Michigan
RATTRAP Offline OP
RATTRAP  Offline OP
N/E, Michigan
What oil option and why is the question!
Re: Rocker pushrod adjusters? [Re: RATTRAP] #3031257
04/06/22 01:50 PM
04/06/22 01:50 PM
It depends on the rocker arm used if you need through the pushrod oiling or through the adjuster oiling to the pushrod tip scope
Some of the high end extruded aluminum shaft mounted rocker arms use oiling through the adjuster in different ways, some have several threads missing for the oil passage and others machine it in the rocker arm adjuster hole scope
Re: Rocker pushrod adjusters? [Re: Cab_Burge] #3031271
04/06/22 02:29 PM
04/06/22 02:29 PM
N/E, Michigan
RATTRAP Offline OP
RATTRAP  Offline OP
N/E, Michigan
I'm using Stage V 426 Hemi lifters and need to order the adjusting screws. Thank you Cab I understand now!
Re: Rocker pushrod adjusters? [Re: RATTRAP] #3031352
04/06/22 06:50 PM
04/06/22 06:50 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Many use a "squirter" hole in the side of the rocker body - aimed in the general direction of the pushrod and in many cases the spring as well. Harland Sharp do not squirt oil at the spring but they do squirt at the pushrod tip. If you're oiling through the pushrod then there's no need at all for any additional holes in the rockers or adjusters. Keep in mind that every place you allow oil to flow equals a reduction in oil pressure.
Re: Rocker pushrod adjusters? [Re: Stanton] #3031448
04/06/22 11:46 PM
04/06/22 11:46 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
I'm still confused because Stage V doesn't make lifters. I'm assuming he's talking about Stage V rockers. So if that's the case, all the Stage V rockers made in the last 10 or 15 years have oiling holes so he doesn't need to worry about it.
2011 Drag Pak Challenger
Re: Rocker pushrod adjusters? [Re: rickseeman] #3031460
04/07/22 05:59 AM
04/07/22 05:59 AM
N/E, Michigan
RATTRAP Offline OP
RATTRAP  Offline OP
N/E, Michigan
Yes Rockers My Mistake.
And they do have the oil holes for the pushrods. up
Re: Rocker pushrod adjusters? [Re: RATTRAP] #3031477
04/07/22 08:29 AM
04/07/22 08:29 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Thru oiling adjusters are used with spray bar oiling only. I did this on my SB with T&D's. You rely on the oil spray to hit the pushrod tips. It works surprisingly well. They call it "spray and pray". I now use HS rockers with pushrod oiling. They oil all the way to the rocker fulcrum and work very well.
Re: Rocker pushrod adjusters? [Re: RATTRAP] #3031488
04/07/22 09:11 AM
04/07/22 09:11 AM
Idaho
boomerodell Offline
boomerodell  Offline
Idaho
The stage v rockers and adjusters I recently purchased from FHO have oil thru adjusters. manton PN 824-01
Re: Rocker pushrod adjusters? [Re: boomerodell] #3031550
04/07/22 12:13 PM
04/07/22 12:13 PM
Byron, NY
Byron, NY
In addition you need to make certain that the Lube hole in the rocker is above the top of the PR cup
'60 Willys CJ5
Re: Rocker pushrod adjusters? [Re: W.I.N. Racing] #3031561
04/07/22 12:51 PM
04/07/22 12:51 PM
N/E, Michigan
RATTRAP Offline OP
RATTRAP  Offline OP
N/E, Michigan
So why would you need oil thru adjuster's, if its shooting oil from the hole in the rocker onto the top of the pushrod?
Re: Rocker pushrod adjusters? [Re: RATTRAP] #3031647
04/07/22 05:18 PM
04/07/22 05:18 PM
Byron, NY
Byron, NY
Added oil to the ball/cup interface. My seat pressure is 340 lbs and 650lbs open. Without the oil hole on the adjuster, Tuneup time and 10 passes blackened two cups and wore half of the adjusters. Replaced the adjusters only with the through hole and over 50 passes no issues starting the season with the same parts as last season.
'60 Willys CJ5
Re: Rocker pushrod adjusters? [Re: W.I.N. Racing] #3031661
04/07/22 06:21 PM
04/07/22 06:21 PM
I bought a used set of B1 heads that had a set of Jesel 1.7 ratio paired shaft rocker arms on them, no provisions in those rocker arms to oil the roller tip or the pushrod tips, shafts and adjuster ends shock
The adjusters are hollow for pushrod oiling, I called Jesel and they said run it, you'll be fine with pushrod oiling only on that set up confused shruggy
I'm going to use a set of spray bar valve covers at first and see how the two work together luck
More to come soon wrench
Re: Rocker pushrod adjusters? [Re: boomerodell] #3052869
06/24/22 06:02 AM
06/24/22 06:02 AM
N/E, Michigan
RATTRAP Offline OP
RATTRAP  Offline OP
N/E, Michigan
Thanks for the Suggested suppler and part#, I called Manton and was surprised on how knowable & helpful the People are there.
After a brief conversation, We agreed that the part number you suggested would be the same one for my application. Also I was told that if there are any issues an exchange would not be a problem. Shipped within an hour after ordering!
Kudos to Manton for their customer service. up
Just wanted to add, That I tried my local Supplier First (TREND PERFORMANCE) The sales guy kept for some reason directing me to a cup style Adjuster, I insisted I wanted a Ball end, And was then told they are out of stock. So I ask what the lead time would be, And was told maybe January shruggy
