70 Heavy Duty Shocks #3030640
04/04/22 03:46 PM
04/04/22 03:46 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Thought I’d throw it out there that I’d like to maintain the stock original look.
Most seem to recommend the Bilsteins that have the least stock appearing look of the options. No doubt a great performer but tough to go this route.
Koni Classic would have a more stock appearance if you painted them black but previous threads mention slight mounting issues in the front and rear, nothing that can’t be overcome
Then I found a “Factory Style” offered by a company called Rare Parts, they appear to be a nice visual option but I can’t say that I know anyone with then, how well they perform, or how well they last.
We know two of the three as being very reliable performance oriented companies. Looking to see if anyone has opinions or have used the Rare Parts option. All are in the same basic price range.
Here’s some pics as reference
6C5A339B-3315-4BA8-9A1F-ED358C9584A2.jpeg5D14F714-FFF0-4559-B7F7-94490364BBA2.jpegB3C19DAF-C196-4848-B1AE-BF397DA3B268.jpeg
Re: 70 Heavy Duty Shocks [Re: AAR#2] #3030641
04/04/22 03:47 PM
04/04/22 03:47 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
And the Rare Parts offering
Re: 70 Heavy Duty Shocks [Re: AAR#2] #3030649
04/04/22 04:03 PM
04/04/22 04:03 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Monroe 32022 front and 32073 rear will cost you about $100 or less for the set of four. Try amazon or google. You just need to paint them black. twocents
Here is one site offering great pricing: https://www.stockwiseauto.com/
Search the parts numbers above.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 70 Heavy Duty Shocks [Re: 70gtx440dana] #3030660
04/04/22 04:34 PM
04/04/22 04:34 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Well from a cost perspective I love the idea but I had a set on the car and that timed out during the build.
2 of the 4 are leaking oil and I’m unsure I want to travel the same path again
Good thought though.
Re: 70 Heavy Duty Shocks [Re: AAR#2] #3030789
04/04/22 11:55 PM
04/04/22 11:55 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
The rare parts shocks look exactly like the Gabriel gas shocks that are for sale on eBay for $100 for all 4. I have had a set on a car for 20 years, no leaks, but of course they are not koni type quality. The only other issue was the front lower bolt sleeve was not serrated where it goes in the control arm, but many new shocks are not, make sure you use a torque wrench and get them tight, also if the inside of the control arm is worn from previous shocks a little weld and grind is in order. Check it out.
Re: 70 Heavy Duty Shocks [Re: 4406bbl] #3030827
04/05/22 08:18 AM
04/05/22 08:18 AM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Honestly the Monroes are fine from a performance perspective for the way this car gets driven. My big hesitation is the current experiance with leaking, 1 front, 1 rear. Of course the cost to step up to one of the 3 options mentioned is a pretty good jump.
