Block Repair Help #3030401
04/03/22 08:28 PM
04/03/22 08:28 PM
Missouri
3
3_RTs Offline OP
3_RTs  Offline OP
Missouri
Does anyone know of or has anyone had their block repaired/welded? The number one rod blew and caused damage to the pan rail area close to the left engine mount surface. Part of the pan rail will need welding also. I''m looking for someone knowledgable and with competent skills in this area. It's the original block to my car.
Re: Block Repair Help [Re: 3_RTs] #3030429
04/03/22 10:11 PM
04/03/22 10:11 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
There’s a guy in Michigan named Rick Petra, third generation, from what I’ve seen does a great job. Don’t have an address he’s on my messenger page and don’t know how to send it to you
Re: Block Repair Help [Re: cudaman1969] #3030435
04/03/22 10:30 PM
04/03/22 10:30 PM
Missouri
3
3_RTs Offline OP
3_RTs  Offline OP
Missouri
Thanks, Cudaman. I will see if I can make contact with him. If you figure it out, please send any info.
Re: Block Repair Help [Re: 3_RTs] #3030488
04/04/22 08:30 AM
04/04/22 08:30 AM
WV
Little Detroit Offline
WV
make sure you find someone with a great reputation for welding cast Iron , to do it correctly it needs to be heated in an oven to a certain temperature and held at that temperature until entire block has reached temperature evenly ,,has to be welded at that temp and heat kept on even keel until repairs are completed , then then cooled in increments over a period of time. saw it done a few times when I was young evidently my memory is as good on exact details as it use to be. Don't just look for car guys for this type of repairs , if possible look to find European or Russian immigrant professional welders as cast iron is a cheaply produced metal widely used in the east and they experts in cast iron repairs. Indy Cylinder head use to do it years ago.
Re: Block Repair Help [Re: 3_RTs] #3030507
04/04/22 10:14 AM
04/04/22 10:14 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
MPD Welding up here in Orion MI can most likely fix it right up.
http://www.mpdweldinginc.com/
Rich H.
Esse Quam Videri
Re: Block Repair Help [Re: ZIPPY] #3030521
04/04/22 10:53 AM
04/04/22 10:53 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Bob Himes 317-831-8069
Mooresville Indiana
Welded a numbers matching 440 Six pack for me years ago with terrific results. BAD shape going in, holes, major cracks, rod left the block....still running to this day almost 16 years later. He has the oven and years of practice. Located just south of Indianapolis.
Todd
Re: Block Repair Help [Re: sasquatch] #3030530
04/04/22 11:08 AM
04/04/22 11:08 AM
Missouri
3
3_RTs Offline OP
3_RTs  Offline OP
Missouri
Thanks for the replies and suggestions, guys! As this is the numbers matching block to my 70 hemi charger, I want someone that knows their sh*t.
Thanks,
Re: Block Repair Help [Re: 3_RTs] #3030650
04/04/22 04:04 PM
04/04/22 04:04 PM
fredericksburg,va
fredericksburg,va
The one I said has all those capabilities mentioned below, using ovens and cooling a little bit over days. Just texted him for his number, got back fast! 708-749-3420
Re: Block Repair Help [Re: cudaman1969] #3030662
04/04/22 04:42 PM
04/04/22 04:42 PM
Missouri
3
3_RTs Offline OP
3_RTs  Offline OP
Missouri
Thank you Cudaman for getting back to me.
Re: Block Repair Help [Re: 3_RTs] #3030773
04/04/22 11:04 PM
04/04/22 11:04 PM
Mattituck NY.
FJ6AAR Offline
FJ6AAR  Offline
Mattituck NY.
1970 Hemi 'Cuda hard top clone
1971 Hemi 'Cuda Convertible clone
Re: Block Repair Help [Re: FJ6AAR] #3030801
04/05/22 01:19 AM
04/05/22 01:19 AM
A727Tflite Offline
A727Tflite  Offline
X
Re: Block Repair Help [Re: A727Tflite] #3030834
04/05/22 09:04 AM
04/05/22 09:04 AM
Mattituck NY.
FJ6AAR Offline
FJ6AAR  Offline
Mattituck NY.
Re: Block Repair Help [Re: FJ6AAR] #3030842
04/05/22 09:31 AM
04/05/22 09:31 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Have those repairs been welded or brazed? Just looking at the bead color.
Re: Block Repair Help [Re: 6PakBee] #3030850
04/05/22 09:53 AM
04/05/22 09:53 AM
Mattituck NY.
FJ6AAR Offline
FJ6AAR  Offline
Mattituck NY.
Re: Block Repair Help [Re: FJ6AAR] #3031020
04/05/22 06:55 PM
04/05/22 06:55 PM
VA
dragon slayer Offline
VA
So what did the repair cost?
Re: Block Repair Help [Re: dragon slayer] #3032089
04/09/22 12:37 PM
04/09/22 12:37 PM
rust belt
Moparite Offline
Moparite  Offline
rust belt
This is brazed! If it where my block make sure it is heated and properly stick welded using a strong alloy welding rod.
Re: Block Repair Help [Re: Moparite] #3033687
04/14/22 10:45 PM
04/14/22 10:45 PM
God's Country Maryland
GODSCOUNTRY340 Offline
I agree, they are both absolutely brazed.
Re: Block Repair Help [Re: GODSCOUNTRY340] #3034077
04/16/22 10:29 AM
04/16/22 10:29 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
agree , but Brazing is an acceptable way to repair cast iron.I think its properties are stronger than cast iron.
Re: Block Repair Help [Re: B1MAXX] #3034096
04/16/22 12:11 PM
04/16/22 12:11 PM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Quote
As per google:
Filler Metal and Flux for Braze Welding The filler metal used for most braze welding is a copper alloy containing roughly 60% copper, 40% zinc, and small amounts of tin, iron, manganese, and silicon.
Not as strong as cast iron. It may be "acceptable" but if i where trying the save a rare hemi block i wouldn't be brazing it.
Re: Block Repair Help [Re: B1MAXX] #3034162
04/16/22 04:55 PM
04/16/22 04:55 PM
Brazing is very soft and has a different expansion rate than either cast grey iron or ductile iron scope
I had my first 400 block brazed up on the deck between #4 and #6 cylinders due to it blowing a head gasket before I bought it, I couldn't find another block so I had it fixed and had to put two sleeves in those cylinder to make the head gaskets and ring seal right up
I had to put two sleeves in #1 and #7 cylinders also due to rust pitting being to deep to seal up at 4.375 bore size, that block was not a good pick to build realcrazy whiney
it did make a lot of power and lived as long as I had it boogie up
