Tic Tok Tach ballast resistor #3030350
04/03/22 06:14 PM
04/03/22 06:14 PM
Usa
A39Coronet Offline OP
Usa
Installed a restored Tic Tok Tach in my 440 RR but remembered it no longer has a ballast resistor on the ignition due to not having a points style distributor. Any reason why this would be an issue or negatively impact the tach?
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Tic Tok Tach ballast resistor [Re: A39Coronet] #3032092
04/09/22 12:47 PM
04/09/22 12:47 PM
rust belt
Moparite Offline
Moparite  Offline
rust belt
" tach's" count the many times a "ground" pulse is given to determine RPM. It will still work with points,MSD or electronic ignition. And the ballast resistor goes on the positive side, constant voltage not the negative.
Re: Tic Tok Tach ballast resistor [Re: A39Coronet] #3032214
04/09/22 09:30 PM
04/09/22 09:30 PM
N
NITROUSN Offline
NITROUSN  Offline
N
A ballast resistor has nothing to to with a factory tachometer.
