241 hemi camshaft #3028851
03/29/22 10:09 PM
03/29/22 10:09 PM
nj pine beach
dart9ss Offline OP
dart9ss  Offline OP
nj pine beach
Looking for a replacement cam or a cam rebuilder. any Ideas?
Re: 241 hemi camshaft [Re: dart9ss] #3028921
03/30/22 09:21 AM
03/30/22 09:21 AM
AZ
Mike P Offline
Mike P  Offline
AZ
https://www.ebay.com/itm/255458311686?hash=item3b7a807e06:g:fpIAAOSw6wxiQMv~
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
Re: 241 hemi camshaft [Re: Mike P] #3028940
03/30/22 10:43 AM
03/30/22 10:43 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I just had a cam reground by Oregon Cam Grinders. Ground it the 235 hp, 273 specs. It is a hydraulic cam. I believe he has cores but you’ll have to give him a call.
You can also give Gary a call, Quality Engineered Components. Good guy, very knowledgeable. He’s out of Bend, OR. 541-388-9214.
Abe Lincoln
Re: 241 hemi camshaft [Re: Mike P] #3029154
03/31/22 11:25 AM
03/31/22 11:25 AM
moparx Online content
moparx  Online Content
try this........ just everything up to the "?".
beer
Re: 241 hemi camshaft [Re: moparx] #3029426
04/01/22 08:31 AM
04/01/22 08:31 AM
AZ
Mike P Offline
Mike P  Offline
AZ
The one thing I noticed on that cam after I tried to post the link is that the cam card shows valve lash settings which to me indicates that it will take solid lifters and adjustable rockers/adjustable push rods. That may or may not be an issue.
Re: 241 hemi camshaft [Re: Mike P] #3029924
04/02/22 10:38 AM
04/02/22 10:38 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
[quote][/quote]
May be an issue money wise. Given the 241 has non adjustable valvetrain he has two routes to go. First, he can go with adjustable pushrods. Through my short experience with these motors they are a PIA to adjust. My 330 runs a hydraulic with those pushrods.
Second choice would be to go with an adjustable valvetrain. It’s a little expensive. There’s a shop in Redding CA that does it.
Abe Lincoln
Re: 241 hemi camshaft [Re: dart4forte] #3029965
04/02/22 01:42 PM
04/02/22 01:42 PM
AZ
Mike P Offline
Mike P  Offline
AZ
“………First, he can go with adjustable pushrods. Through my short experience with these motors they are a PIA to adjust……”
I hear you I just got the heads on my motor. Next step is to adjust the pushrods. Not looking forward to it, but at least the engine is on the stand. It’s a X2 PIA to adjust them in the car. At least with hydraulics you should only have to do it once. A solid lifter cam that chore becomes a once in a while job.
Re: 241 hemi camshaft [Re: Mike P] #3029967
04/02/22 01:48 PM
04/02/22 01:48 PM
is there enough factory valve cover clearance to run adjustable rockers ?
i'm thinking of the dimples in the valve covers the solid cam 354[?] had in the chrysler 300's. [shruggy]
beer
Re: 241 hemi camshaft [Re: moparx] #3030079
04/02/22 08:38 PM
04/02/22 08:38 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
beer
Yes, the rocker adjustment screws are machined to clear.
Abe Lincoln
Re: 241 hemi camshaft [Re: dart9ss] #3030448
04/03/22 11:17 PM
04/03/22 11:17 PM
P
Ply36 Offline
Ply36  Offline
P
The shop that did my 241 sent the original cam to Iskendarian Cams where it was re-ground. Very happy with the results
Re: 241 hemi camshaft [Re: Mike P] #3111429
01/13/23 12:51 AM
01/13/23 12:51 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
My mistake, it’s actually a solid cam
Abe Lincoln
Re: 241 hemi camshaft [Re: dart9ss] #3199723
12/23/23 09:38 PM
12/23/23 09:38 PM
P
Ply36 Offline
Ply36  Offline
P
I had the cam in my 241 reground by ISKY.. It's been about 15 years and no problems.
