Re: Victor 440 Vs Trickflow
[Re: mercman1]
#3028583
03/29/22 08:20 AM
03/29/22 08:20 AM
Posts: 1,146 Loudoun County, VA
Brad_Haak
Loudoun County, VA
I've tested both on different engines, so no direct comparison. Out of the box, the Trick Flow is better, IMO. In ported form, I expect they would be very close. The engine that is in the car now awaiting final reassembly of the chassis has a Trick Flow, FWIW.
EDIT: You asked for HP & torque numbers... the engine combination using a Victor w/ some plenum mods & port matching made 600+ HP / 570+ Tq; a revised engine combination with better heads, etc. using a Trick Flow with minimal plenum cleanup work made 670+ HP / 600+ Tq.
The car w/ the 600+ HP engine ran mid-to-high 10s at 123-126 MPH, depending upon the time of year. The new engine hasn't been to the track, yet.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: AndyF]
#3028623
03/29/22 10:33 AM
03/29/22 10:33 AM
Brad_Haak
Loudoun County, VA
... I don't think the Trick Flow intake is available at the moment, not sure about the Victor. Well, from what I see neither are likely available. Summit says Trick flow is 4 months out and Edelbrock is 2 months out. Not the only source, but if Summit doesn't have them, it's a good indication they may be hard to locate.
[Re: Brad_Haak]
#3028625
03/29/22 10:36 AM
03/29/22 10:36 AM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Is there adequate hood clearance on the vehicle for either of them?
[Re: fast68plymouth]
#3028926
03/30/22 09:42 AM
03/30/22 09:42 AM
Brad_Haak
Loudoun County, VA
Is there adequate hood clearance on the vehicle for either of them? Good point; both of those intakes are probably 1.5" -- maybe more -- taller than a Street Dominator.
