Re: fuel injection progress
[Re: 8urvette]
#3028483
03/28/22 08:24 PM
03/28/22 08:24 PM
Posts: 781 wine country
8urvette
wine country
by the end of the weekend this is where i got it to.
[Re: FastmOp]
#3028498
03/28/22 09:35 PM
03/28/22 09:35 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
Now you know the ins and outs of all of it and how it works, it will make it easier to diagnose should you ever have a problem. That doesn't mean its fun though lol.
I had that same throttle body and my 418" was still pulling several KPAs of vacuum on it at wide open throttle(compared to barometric sensor), so I added another one to fix the problem lol.
68 Barracuda Formula S 340
[Re: Bad340fish]
#3028502
03/28/22 09:44 PM
03/28/22 09:44 PM
Posts: 2,255 IL
furious70
IL
wow!!! My universal fit harness on my classic FAST setup in my Fury don't look great, but I don't know that I could handle that right there. Kudos to you!
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: 451Mopar]
#3028524
03/28/22 10:16 PM
03/28/22 10:16 PM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
Yes it's a bit of work. I bought a universal harness and ended up tearing the entire thing down to add a bunch of stuff and get the wire lengths where I wanted. So what you're doing is really the way to go IMO, unless you aren't picky about aesthetics.
[Re: Bad340fish]
#3028541
03/28/22 11:29 PM
03/28/22 11:29 PM
8urvette
wine country
I had that same throttle body and my 418" was still pulling several KPAs of vacuum on it at wide open throttle(compared to barometric sensor), so I added another one to fix the problem lol. I took my time, pinned out the entire harness, labeled everything and then went to work. Happily one 2 wires didnt match what Holley claimed. They were in the right spots, just not the colors they were supposed to be. No biggie, i noted it and moved on. Yea it isnt what I had originally wanted, same with the intake. But the parts I did want won't be in stock till late may or early June... assuming it doesnt get bumped back again. So I chose what was in stock and could get me moving down this road.
[Re: 8urvette]
#3028560
03/29/22 05:34 AM
03/29/22 05:34 AM
Posts: 4,647 aotearoa
rebel
aotearoa
I went with MPI on my tunnel rzm with the Holley harness. Still spent 2x nights modifying thd supplied harness to match my car. Hopefully by next season I'll have it dyno'd & ready to ho racing.
[Re: 8urvette]
#3028727
03/29/22 02:59 PM
03/29/22 02:59 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I had to do that on the hot rod back in 2003. I had an ECU, a few plug housings, and a handful of connectors. It took me a full weekend using a gooseneck flatbed trailer as a work bench but I got it figured out. The hard part was sourcing enough different colored wires.
Like the others said, I wasn't afraid of chasing wire gremlins over the years.
[Re: Dragula]
#3029225
03/31/22 02:25 PM
03/31/22 02:25 PM
8urvette
wine country
So glad I went Sniper 4500 this time. I think it took me 3hrs to install and wire it....
I really thought about the 4500 sniper. But I wanted a little more tune ability for the future. Even recently like 2 weeks ago I was looking at that again. Thankfully holley said it was out of stock!
[Re: Dragula]
#3029228
03/31/22 02:32 PM
03/31/22 02:32 PM
Posts: 19,464 north of coder
moparx
wiring is an intimidating black art until one tries it from scratch. it does indeed take lots of time and concentration to do it, but is very gratifying when completed, with the added benefit of you being able to trouble shoot it when/if needed. the only thing i might add, is make sure you have a good crimping tool that matches your connectors and terminals. a couple of practice crimps to make sure you make solid connections is recommended if you are not sure of yourself. don,t feel bad, i do practice crimps myself if i haven't used a particular crimp tool for a while, although i have wired many vehicles in the past 50 years or so. marine heat shrink tubing is better than the normally available stuff, in that it has sealing glue that is activated when you shrink the tubing. you might consider this where moisture may be a problem or concern.
[Re: moparx]
#3029267
03/31/22 04:36 PM
03/31/22 04:36 PM
Bad340fish
Tulsa OK
I keep telling myself I enjoy it. I put EFI on my car in 2015, then winter of 2020 I took it all out, added an additional ECU and re did most of it. Once I pulled it all out again I began to question my sanity. I am real good at making it work, I am not the best at making it pretty. But it works, and its serviceable and expandable. Not pictured are 3 relay boards.
It would be way easier to make pretty if it wasn't under the dash and I didn't have a roll cage ha.
