TF998 Fluid Question.
#3027184
03/24/22 07:00 PM
03/24/22 07:00 PM
Posts: 4,798 Castlegar, BC, Canada
That AMC Guy
Just about to fire up my '88 RAM for the first time. The engine was yanked in 2016, and I've spent the last few months putting it back together. Transmission was drained when the engine was removed.
Can't find and have been told Dexron III is obsolete. I was pointed to this Mobil brand stuff called D/M and on the back, it claims to be the modern equivalent of Dexron/Mercon III and is compatible with vehicles designed for that blend.
Anybody else run it? Good to go? Thoughts?
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
Re: TF998 Fluid Question.
[Re: That AMC Guy]
#3027237
03/24/22 09:42 PM
03/24/22 09:42 PM
Posts: 1,607 westerly, ri. usa
440lebaron
westerly, ri. usa
atf4 supersedes most mopar atf's its available anywhere
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: Sniper]
#3027358
03/25/22 11:52 AM
03/25/22 11:52 AM
Posts: 25,857 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If the trans has a lockup converter (likely) then ATF+4 is the correct fluid. For a non-lockup 3-speed, Type F is fine.
[Re: 360view]
#3027686
03/26/22 10:07 AM
03/26/22 10:07 AM
Posts: 3,082 Michigan
A727Tflite
If the shaft torque applied exceeds the clutch friction holding torque, which depends on the ATF friction coefficient, how quickly do the clutch frictional surfaces wear to the point that they must be replaced in a rebuild?
Can it happen in one or a few dragstrip passes, or one or a few maximum highway accelerations?
I ask because I once changed out ATF+3 to ATF+4 on a high mileage 46RH.
After the change out I did a few full throttle accelerations up a steep high hill. Everything seemed OK, but a few hundred miles later the TC clutches began slipping, and a few hundred miles after that the overdrive unit clutches began slipping.
I later read in an SAE technical paper co-authored by Lubrizol Company and Chrysler that ATF+4 has a lower clutch friction coefficient than ATF+3, although ATF+4 has other numerous advantages. Why did you change the fluid to start with?
[Re: A727Tflite]
#3027824
03/26/22 06:02 PM
03/26/22 06:02 PM
Posts: 11,602 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
ATF+3 has superseded to +4.
Late model trans, stock, lock up, daily driver, ATF+4.
Performance, race, non-lock up, something else. Type F probably, Or synthetic Type F. Or Dexron.
[Re: A727Tflite]
#3027828
03/26/22 06:19 PM
03/26/22 06:19 PM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
I later read in an SAE technical paper co-authored by Lubrizol Company and Chrysler that ATF+4 has a lower clutch friction coefficient than ATF+3, although ATF+4 has other numerous advantages. Why did you change the fluid to start with? The old ATF+3 was at the 30,000 mile interval. Neither Torque Converter Clutch or Overdrive Clutch was slipping before the change, but every now and then the trans was “bump shifting” while the truck was coming to a stop. After the ATF+4 and a new filter went in, the bump sifting was not felt anymore.
[Re: 360view]
#3027837
03/26/22 06:50 PM
03/26/22 06:50 PM
A727Tflite
I later read in an SAE technical paper co-authored by Lubrizol Company and Chrysler that ATF+4 has a lower clutch friction coefficient than ATF+3, although ATF+4 has other numerous advantages. Why did you change the fluid to start with? The old ATF+3 was at the 30,000 mile interval. Neither Torque Converter Clutch or Overdrive Clutch was slipping before the change, but every now and then the trans was “bump shifting” while the truck was coming to a stop. After the ATF+4 and a new filter went in, the bump sifting was not felt anymore. Did it set any codes? What makes you think the OD was slipping?
[Re: 360view]
#3028227
03/28/22 05:27 AM
03/28/22 05:27 AM
That AMC Guy
I was surprised to see my dipstick is stamped "Use Type 7176 or Dexron II " Yes, Dexron II. So, if this Mobil says it's the direct descendant of Dexron III / Mercon III.... I guess I'll give it a try.
