Not Mopar Related BUT Engine Related, VHT Paint Question..
#3026882
03/23/22 08:00 PM
03/23/22 08:00 PM
Posts: 555 Berlin, CT
SportFuryS/23383
Confused
Confused
Berlin, CT
Hi Everybody,
I kind of went on a shopping spree at one of my local AutoZone's a couple days ago on Monday, and of course I left with more stuff than I went in for. I bought Mopar t-shirts and an American flag t-shirt that I really liked for only $10.00 each, a beer hat for a beer that I actually drink, and what I went in for which was more Meguiars 105 Compound and more VHT gloss white engine paint. While I was getting my engine paint I noticed this VHT gloss clear engine enamel stuff next to my engine paint on the shelve in my picture below, and was debating on getting it for when I eventually paint an engine on one of my tractor projects to make it a bit shinier OR maybe to re-repaint another engine on another one of my tractors. Has anyone used it?, is it any good?, or should I just stay away from it and not get it?
Any opinions, advice, and help is always much appreciated.
Thanks.
If You Ask Me This Whole World Has Gone To Hell- Creed Fisher Proud Supporter Of LGBT (Liberty Guns Beer & Trump)
Re: Not Mopar Related BUT Engine Related, VHT Paint Question..
[Re: SportFuryS/23383]
#3026968
03/24/22 02:03 AM
03/24/22 02:03 AM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
I've had very good results with VHT spray bombs. Good stuff, but make sure it won't lift the paint like a paint remover on previously painted stuff.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: BigFish69]
#3027271
03/25/22 12:38 AM
03/25/22 12:38 AM
Posts: 5,166 CT
GTX MATT
CT
I used it in some bare stuff so it wouldn’t rust, works nice and is glossy.
[Re: GTX MATT]
#3027289
03/25/22 06:15 AM
03/25/22 06:15 AM
Posts: 4,786 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Might as well try it. Keep in mind spray cans do not have the hardeners that the mixed/spray gun stuff has so does not cure "hard." There is a two part disposable aerosol clear coat called SprayMax2k. Its the real deal- you puncture an internal bladder and then shake the can mixing the hardener with the clear. Then you must use the can within several hours or it cures in the can. HOWEVER..... in the motorcycle world users have found out it yellows when exposed to heat.
Keep old mopars alive.
[Re: 2boltmain]
#3027306
03/25/22 09:10 AM
03/25/22 09:10 AM
Posts: 34,937 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
autozones #1 selling item I've been told, Peanut M&M's at checkout
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: bigdad]
#3027716
03/26/22 11:41 AM
03/26/22 11:41 AM
Posts: 724 Southern Alberta
Uberpube
Southern Alberta
autozones #1 selling item I've been told, Peanut M&M's at checkout I can't walk by a coin operated candy vending machine without spending at least a buck.
[Re: Uberpube]
#3027723
03/26/22 11:56 AM
03/26/22 11:56 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
autozones #1 selling item I've been told, Peanut M&M's at checkout I can't walk by a coin operated candy vending machine without spending at least a buck. They sell them in 1/2 bags now ?
[Re: A/MP]
#3029219
03/31/22 02:05 PM
03/31/22 02:05 PM
Posts: 19,562 north of coder
moparx
single stage automotive paint with hardener works well, and the colors are unlimited. you can get them put into spray cans with a button you push to release the hardener, then shake the $hit out of them to mix, then spray away. unfortunately, if there is any left in the can, it won't last long, so have a bracket or two ready you can spray with what remains in the can.
