Trans cooler size #3026100
03/21/22 04:53 PM
03/21/22 04:53 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
What are your thoughts on using a 11"x 10"x 3/4"trans cooler for street strip ?
With the amount of metal from oil pump failure i doubt i can flush my old tube cooler out .
I do have 5000 plus converters . Never saw any temp issues before , i have a gauge in 1 trans with a 6000 stall
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Trans cooler size [Re: tex013] #3026277
03/22/22 08:20 AM
03/22/22 08:20 AM
an8sec70cuda Offline
That's roughly the same size as the one I've had on my cuda for 24+ years now. It came from the local auto parts store and works great.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Trans cooler size [Re: an8sec70cuda] #3026405
03/22/22 02:40 PM
03/22/22 02:40 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
should be ok, keep a eye on the temp, that's a lot of converter for the street I think
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Trans cooler size [Re: tex013] #3026455
03/22/22 04:41 PM
03/22/22 04:41 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I put this on my car a cpl yrs ago but not much info.I made 1 pass last yr and the temp was 140*
