97 3500 CTD dully wheels #3025259
03/18/22 07:34 PM
03/18/22 07:34 PM
Ontario Canada
Bennoel 10 Offline OP
Ontario Canada
Wondering what year/years my wheels from my 1997 Dodge one ton dully 2 wheel drive will fit. I'm sure 2000 and up are different and trying to figure out if they will work on a 1993 truck of the same description ?? Thanks for any and all input.
Re: 97 3500 CTD dully wheels [Re: Bennoel 10] #3025311
03/18/22 10:14 PM
03/18/22 10:14 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Re: 97 3500 CTD dully wheels [Re: 3hundred] #3025947
03/21/22 08:24 AM
03/21/22 08:24 AM
Ontario Canada
Ontario Canada
Originally Posted by 3hundred
I don't think there's any swapping '93 and older with '94 and newer. IIRC, 1994 they changed from lug centric to hub centric? Then in 2000 they changed the wheels again to have more offset to fit P235/85R/16 tires. The newer wheels foul the tie rod ends of the '94-''99 model years. Then on '03 they went to 17" wheels, in '18 I think the bolt circle changed?
Thanks for your help
