Botching my Cam Swap #3024906
03/17/22 03:16 PM
03/17/22 03:16 PM
Mid TN
2BblHarold Offline OP
Mid TN
I just did a cam swap on my 318, and I'm getting no love on start up. It barely runs for 3 seconds at a time. It actually behaves like the one time long ago my timing chain slipped on me, so my hunch is that the cam is out of synch. Facts to know:
I installed the timing gear dot to dot. Standard key, no offset. I did not degree the cam. Cyl #1 at TDC. I realize that this will be TDC ignition stroke for #6. (Correct?) Timing gear and chain had about 3,000 miles, so basically new.
I used a torque wrench throughout. With the build complete, I hand-rotated the crank once or twice to make sure everything spun, no problems detected.
On fireup, I made sure the rotor was at #6 while crank was at TDC. I got some putter-putter, but no real firing, played with a few timing settings, no love. So I second guessed myself and reset the distributor 180 off. This time there was immediate fire, yes, outside the carb, so I knew I had it right the first time.
I reset the distributor back to normal, and this time I got a little bit of firing...super low rpms, but it just wouldn't open up, even though I swept the dizzy through its entire range. Next, I reasoned my way through a reset of the intermediate shaft, thinking that I could sweep the dizzy through a different range of degrees, if you follow. (I'll add as an aside that it seems curious that we never talk about correctly referencing the slot for the distributor as part of an initial setup, maybe I'm thinking too hard).
Carb and ignition worked fine before, newer Holley 600 is confirmed to be flowing.
I have no reason to believe the stock balancer has rotated. Timing was fine on my last build of this same motor a few years ago.
I've done this job twice with success, I'm no expert but I'm a bit baffled as to where I went wrong.
Any thoughts appriciated.
Re: Botching my Cam Swap [Re: 2BblHarold] #3024908
03/17/22 03:23 PM
03/17/22 03:23 PM
N
NITROUSN Offline
NITROUSN  Offline
N
TDC compression stroke on number one cylinder with the marks lined up and see where the rotor is pointing.
Re: Botching my Cam Swap [Re: NITROUSN] #3024910
03/17/22 03:27 PM
03/17/22 03:27 PM
Mid TN
Mid TN
Well the marks are all buttoned up now.
But during the build, I knew that with dot to dot, the rotor should be at #6, and that's where it lined up to when dropped the distributor in. Seemed normal.
Re: Botching my Cam Swap [Re: 2BblHarold] #3024919
03/17/22 04:10 PM
03/17/22 04:10 PM
N
NITROUSN Offline
NITROUSN  Offline
N
That's not what I said. Pull number one plug. Bump it over until on compression. Rotate to line up line on balancer to 0 on tab. Then see where the rotor is pointing.
Re: Botching my Cam Swap [Re: 2BblHarold] #3024927
03/17/22 04:52 PM
03/17/22 04:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
How long did you crank the engine over... are you sure the lifters were pumped up
wave
Re: Botching my Cam Swap [Re: NITROUSN] #3024936
03/17/22 05:16 PM
03/17/22 05:16 PM
Mid TN
Mid TN
Gotcha! I mistook timing marks for cam dots in your comment, understood.
Re: Botching my Cam Swap [Re: MR_P_BODY] #3024937
03/17/22 05:20 PM
03/17/22 05:20 PM
Mid TN
Mid TN
Mr P, no I'm not sure. I ran my drill to the oil pump but something seemed a little off, maybe I did not engage the pump and my pre-oil procudure failed. I did pump up the lifters when I installed them, but that was two months ago. So maybe I'm just not getting strong enough valve action. I had several 10 sec cranks.
Re: Botching my Cam Swap [Re: 2BblHarold] #3024975
03/17/22 07:43 PM
03/17/22 07:43 PM
St.Pete,Florida
lancer493 Offline
lancer493  Offline
St.Pete,Florida
I may be misinformed but I thought the current recommendation was not to pump up hydralic lifters before installing so as not to hang some valves open before they can bleed down to proper capacity. I've installed many sets without pumping them up. Start with a compression check on a couple of cylinders after verifying your pre-lube technique. Bill
Re: Botching my Cam Swap [Re: lancer493] #3024981
03/17/22 07:55 PM
03/17/22 07:55 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Is this a brand new, flat tappet cam? How long have you been trying to start it? The break-in lube is probably gone at this point and firing it now would wipe the cam on break-in. Motor needs to fire almost immediately when breaking in a new flat tappet.
Re: Botching my Cam Swap [Re: 2BblHarold] #3024985
03/17/22 08:08 PM
03/17/22 08:08 PM
Cab_Burge Online work
Cab_Burge  Online Work
Make a piston stop out of a old spark plug by knocking out the center electrode and porcelain insulator and use a long enough 1/4 bolt to hit the piston top around 20 to 30 degrees before and after TDC to make sure the dampener has not spun the outer ring with the TDC timing line on it scope wrench
I had a old 318 truck poly motor car hauler backfire in the driveway when cold making the timing change jump one tooth, it was real lazy and I couldn't make it run properly until I replace that timing set shruggy
Good luck up
Let us know what you find out about what went wrong scope work
Re: Botching my Cam Swap [Re: MarkZ] #3024987
03/17/22 08:16 PM
03/17/22 08:16 PM
Mid TN
Mid TN
Yes Mark, flat tappet. This is one of my worries, that I've already wiped the lube and need to break it down and re-apply. Proably 60 seconds of combined cranking.
As for the recent pump-up-or-not-pump-up thread, yes I recall more of a consensus to NOT pump them. This came to light, to me anyway, an hour after I pumped them! Assuming that my lifters have been under pressure for a few hours now, maybe I can bump the starter to put a load on a few more lifters, and they will unpump a bit overnight. Comp check is a good call too, thanks!
Re: Botching my Cam Swap [Re: Cab_Burge] #3024991
03/17/22 08:20 PM
03/17/22 08:20 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Some cam and crank gear markings can be misleading. Without seeing what you put in there it would be hard to say that is the problem. Degreeing it would rule out that problem. I ran into a problem years ago so I do not trust the dots.
Re: Botching my Cam Swap [Re: NITROUSN] #3025004
03/17/22 09:07 PM
03/17/22 09:07 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i wonder if the intermediate gear slot is not in the correct orientation and the distributor can't provide enough timing?
Re: Botching my Cam Swap [Re: lewtot184] #3025025
03/17/22 10:37 PM
03/17/22 10:37 PM
Mid TN
Mid TN
Yes, I wonder this too about the intermediate shaft. It makes me wonder why I've never seen this subject come up. I did reset it once during my session today. I'm guessing the intial set up of the shaft should be such that the slot is in line with the #1 and #6 terminals.
Re: Botching my Cam Swap [Re: 2BblHarold] #3025054
03/18/22 05:05 AM
03/18/22 05:05 AM
A727Tflite Offline
A727Tflite  Offline
The orientation of the intermediate shaft means nothing.
As long as at TDC on #1 cylinder the rotor lines up with #1 wire you are good.
The reason the service manuals show the orientation is so that by following the procedure the average person will be able to have enough distributor movement without the vacuum advance unit crashing in to anything.
The procedure came from the engine test stand assembly procedure when the engine was tested at Chrysler.
Follow what Nitrousin said . Get TDC on #1, with both valves closed, and check the rotor location.
I doubt your lifters are the issue after all the attempts to start the engine.
Re: Botching my Cam Swap [Re: A727Tflite] #3025062
03/18/22 07:18 AM
03/18/22 07:18 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
the slot doesn't matter IF you don't care about plug wire location on the cap. if the plug wire location on the cap is correct then the slot needs to be correct to allow for proper distributor movement. some people don't care; i do.
Re: Botching my Cam Swap [Re: lewtot184] #3025079
03/18/22 08:51 AM
03/18/22 08:51 AM
Mid TN
Mid TN
Thanks y'all, all advice sounds good. Hope to get at it later today.
Re: Botching my Cam Swap [Re: 2BblHarold] #3025090
03/18/22 09:30 AM
03/18/22 09:30 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Go back and start the whole valve and ignition procedure again... if you need help just ask
wave
Re: Botching my Cam Swap [Re: 2BblHarold] #3025098
03/18/22 09:55 AM
03/18/22 09:55 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
If you really think your cam is installed wrong, take off the valve cover rotate engine and watch the intake and exhaust valves. When rotating the exhaust valve will open then start to close, keep rotating slowly and the intake will begin to open, when the balancer gets to zero this is the overlap period, basically both valves should be open and by the same amount. Exhaust closing and intake opening. If one is open a lot more than the other your cam is out of phase. If you use a dial indicator you can check for advance and retard, if the cam is open a few thousands more on the intake it is advanced, the exhaust open more it is retarded. If you are at least a tooth off, you should be able to see the difference with your eye. And when setting your distributor, remember your coil does not fire at zero TDC it fires 10 to 20 degrees before TDC.
Re: Botching my Cam Swap [Re: MarkZ] #3025216
03/18/22 04:42 PM
03/18/22 04:42 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Ideally yes but I've had two instances where we spun the motor over for a heck of a lot.longer than OPs stated 60 seconds and both motors were fine. One is videoed on my YouTube channel where we were trying to do break in in cold weather. Both times the cam was fine and the car went on to make 100s of 1/4 mile hits without issue. I've had guys tell me "if it don't start on the third spin take the cam out it's junk". Doubtful.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
