1970-71 26" fan shroud measurements #3024459
03/16/22 07:45 AM
03/16/22 07:45 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Anyone have a fan shroud for the 70- 71 B or E bodies with a 26" radiator . able to measure the mounting point locations please .
Re: 1970-71 26" fan shroud measurements [Re: gtx6970] #3024698
03/16/22 08:47 PM
03/16/22 08:47 PM
BLACKHEMIRR Offline
BLACKHEMIRR  Offline
The side to side distance is about 25 7/8”, and the vertical distance is about 12 3/16”. They’re bolt hole center to center measurements.
Re: 1970-71 26" fan shroud measurements [Re: BLACKHEMIRR] #3024718
03/16/22 09:58 PM
03/16/22 09:58 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Ok thanks. I think I can make that work on this radiator .
I just ordered one
Re: 1970-71 26" fan shroud measurements [Re: gtx6970] #3024817
03/17/22 10:59 AM
03/17/22 10:59 AM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Bill would the "326" shroud work with your rad?? That's what I had to use on mine with an aftermarket rad.
Ron
Re: 1970-71 26" fan shroud measurements [Re: RJS] #3025026
03/17/22 10:50 PM
03/17/22 10:50 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Ron
Sure think so.
I ordered one this morning . Should be here monday
I need / want to get rid of the crappy looking one a previous owner cobbled up to put on it
It will get new battery cables, OEM chrome valve covers.
Just got a new valve cover breather from Tony D
Replacement heater core is enroute. As are front suspension stuff. .'
I plan do a partial charge / dye test next week to ck the AC leak . Was told its condenser . But want to verify that before ordering a $400 part
Drove it to a local cruise tonite. Car ran pretty good for whats supposed to be a low compression 440
