What's your go-to rust inhibitor? #3023935
03/14/22 12:32 PM
03/14/22 12:32 PM
Knoxville, TN
Y
YGBSM Offline OP
YGBSM  Offline OP
Y
Knoxville, TN
Yes, I know rust never sleeps, just trying to buy some time.
I've used Permatex before and it seems to be OK. Are they all the same or are some better?
Thanks!
1968 Charger R/T
2015 Charger R/T Scat Pack
2017 Durango Citadel
Re: What's your go-to rust inhibitor? [Re: YGBSM] #3024066
03/14/22 09:31 PM
03/14/22 09:31 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
From the paint type category, I've used Bill Hirsch Miracle Paint, POR15, and a 2 or 3 parts system from Eastwood. All worked well. The Bill Hirsch product got quite a work out trying to preserve an '86 Omni against Michigan winters, and the Eastwood product was applied to a steel lintel on my house that is outdoors 24/7, and has held up well. The POR15 was mostly used on my Charger back in the early '90s, and has never been on the road, so no testimonial there.
Most recently I bought some KBS coatings for a couple of axles that need some preservation, but I have not had a chance to use it yet. I was going to coat an 8.75 for the Chrysler, then we had the garage fire, and haven't got back up and running yet. So no testimonial there yet either.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: What's your go-to rust inhibitor? [Re: DynoDave] #3024076
03/14/22 10:33 PM
03/14/22 10:33 PM
Between Houston & Galveston TX
SattyNoCar Online work
SattyNoCar  Online Work
I cringe whenever I see someone boast about how great POR15 is. Unless something has changed in the last 20 yrs, I'll never use it again No salted roads here, just salty air being close to the coast. I closely followed the instructions to a 'T' and the POR15 actually seemed to speed up the rusting process. confused
I have two fenders over in storage that one was painted with Rustoleum the other with POR15 20+ yrs ago. Neither fender made it back onto a car, so they have been sitting in storage all this time. Guess which one shows signs of rust............. eyes
Watching this topic with interest to see what people are using and recommending now. popcorn
John
Re: What's your go-to rust inhibitor? [Re: SattyNoCar] #3024087
03/14/22 11:47 PM
03/14/22 11:47 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
My brother put POR-15 on the trunk pan of a car and it rusted underneath it. It did a great job of hiding what it was doing for a long time until a sheet of it popped up. No way I'd use it for anything.
Re: What's your go-to rust inhibitor? [Re: Neil] #3024098
03/15/22 01:35 AM
03/15/22 01:35 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Search You Tube for "sweet project cars rust".
This might be what you are looking for. There's a list of ingredients and sourcing below the video.
Re: What's your go-to rust inhibitor? [Re: YGBSM] #3024123
03/15/22 09:33 AM
03/15/22 09:33 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
From what I gathered of the OP's "Permatex" reference he might be looking for a product cooling system related shruggy I use Wynn's cooling system cleaner for the flush then the cooling system treatment with new coolant. I've been using it for decades with good results twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: What's your go-to rust inhibitor? [Re: fourgearsavoy] #3024259
03/15/22 03:11 PM
03/15/22 03:11 PM
Columbus, GA
Michael Ecks Offline
Columbus, GA
Gus beer
Pretty sure he is talking about Permatex Rust Treatment spray. From what I can tell by having used all three recently it is the exact same as Loctite Extend Rust Neutralizer and Rust-Oleum Rust Reformer. All of the instructions say that that they are rust converters and may actually cause rust if used on unrusted metal. I've always used as per the instructions, scuffed after full drying period and topcoated with no bad results to speak of. But it has always been small parts or small areas, and watch for overspray as it will discolor other paint. I am sure there is probably a better product for covering large rusty areas, or combination converter/encapsulators.
For preventing initial rust formation on bare metal I've heard good things about Rust Prevention Magic, but have yet to open the can that I have. IIRC it is wax based so probably not something you want to try to paint over.
If you are going to paint and protect bar metal, I'm thinking its hard to beat careful metal prep and catalyzed epoxy primer and sealer.
Good Luck
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: What's your go-to rust inhibitor? [Re: YGBSM] #3024305
03/15/22 04:52 PM
03/15/22 04:52 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
My go-to is a sandblaster or wire wheel, acid wash/neutrailize if needed, 2x wipe with wax and grease remover, wait 30 minutes, tack cloth and blow,
and shoot 2 or 3 coats of black epoxy primer, either PPG or SPI.
So far, I have not found anything better that the above.
As far as a product to apply to rust itself....
Recently I tried Rust Bullet on some inner roof structure and it is considerably more user friendly than POR. but 20 years from now
will be the time to do a review on it.
I hate POR15 and will never use it again/bad experience. A large area I used it on failed, leading to the sandblast/epoxy prime routine.
Rich H.
Esse Quam Videri
Re: What's your go-to rust inhibitor? [Re: ZIPPY] #3024320
03/15/22 05:53 PM
03/15/22 05:53 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Originally Posted by ZIPPY
and shoot 203 coats of black epoxy primer, either PPG or SPI.
How many days does that take?
Don't you just hate auto correct? runaway
Re: What's your go-to rust inhibitor? [Re: GomangoCuda] #3024399
03/15/22 09:23 PM
03/15/22 09:23 PM
northeast ohio
hulmule Offline
hulmule  Offline
northeast ohio
Are you going to paint what ever it si? POR's 15 sucks..... never again... Live in ohio, so in non wash areas as in side doors , fender etc. Like fluid film. High wash areas as in the frame fluid film tends to wash away. There's another product ,called wool wax. But if painting , blast, and use a good etching primer.
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: What's your go-to rust inhibitor? [Re: YGBSM] #3024414
03/15/22 10:30 PM
03/15/22 10:30 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Thanks!
Are you asking about an Inhibitor?
For only storage of a cleaned item.
Or a Preventive, for under paint & such?
Re: What's your go-to rust inhibitor? [Re: PhillyRag] #3024470
03/16/22 08:53 AM
03/16/22 08:53 AM
Knoxville, TN
Y
YGBSM Offline OP
YGBSM  Offline OP
Y
Knoxville, TN
Thanks for all the replies. Yes, I meant the Permatex rust killer- but the bottle I bought long ago was not a spray. It was a liquid you spread on with a brush. Y'all have given me a lot to think about, I appreciate the information. Especially about POR-15!
1968 Charger R/T
Re: What's your go-to rust inhibitor? [Re: YGBSM] #3024505
03/16/22 10:38 AM
03/16/22 10:38 AM
Corpus Christi, TX
shanker Offline
shanker  Offline
Corpus Christi, TX
for an inhibitor I either use Surface Shield ( https://blasterproducts.com/product/surface-shield/ ) or Fluid Film ( https://www.fluid-film.com/ )
For rust TREATMENT, I've switched over to exclusively using Corroseal ( https://corroseal.com/ )
To paint over treated rust, I use KBS Rust Seal ( https://www.kbs-coatings.com/rustseal.html )
Por15 is an old technology product, good when used correctly, but not great and has been surpassed by competitors.
I grew up on a Gulf Coast ranch and live on the gulf coast, it's a constant battle with corrosion.
The Federal Government has not yet learned that you cannot legislate morality 1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23 1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55 1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91 1975 Duster 360 VS29L5 Daily Driver
Re: What's your go-to rust inhibitor? [Re: GomangoCuda] #3024574
03/16/22 02:00 PM
03/16/22 02:00 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Dangit smile Fixed
Rich H.
Esse Quam Videri
Re: What's your go-to rust inhibitor? [Re: ZIPPY] #3025016
03/17/22 09:34 PM
03/17/22 09:34 PM
Chicago
PurpleBeeper Offline
Chicago
There are several related topics here.
1. to prevent rust on new, fresh metal, you prevent oxygen from getting to it. Best is a zinc rich primer, epoxy, then urethane/acrylic for sunlight exposure (if necessary).
2. for short-term rust prevention on new, fresh metal, most rust preventers are simply mineral oil in a spray can
3. you can make "fancy" mineral oil in a spray can and want a little bit of rust-neutralizing action, you add an organic acid, like oleic acid, to your mineral oil spray can
4. longer term rust prevention storage, try some wheel bearing grease or thick motor oil (e.g. machined block, crank, etc)
5. to truly neutralize rust, you need a stronger acid and phosphoric acid is preferred. After reacting with rust (& literally removing it), a byproduct of that reaction is iron phosphate...which is moderately effective rust inhibitor coating, so you get a 2-for-1 action with phosphoric acid.
For me, I cut out all major rust. Then I brush in a phosphoric acid 1-component "rust neutralizer" like in most parts stores to get the tiny lit pits of rust neutralized (note: sandblasting is way better). Epoxy over everything. If exposed to sunlight, polyurethane primer on top of that......then paint as needed.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: What's your go-to rust inhibitor? [Re: PurpleBeeper] #3025017
03/17/22 09:45 PM
03/17/22 09:45 PM
Nor here, Nor there
Dart 500 Offline
Dart 500  Offline
Nor here, Nor there
Corrosion free or fluid film
Re: What's your go-to rust inhibitor? [Re: Dart 500] #3025059
03/18/22 06:47 AM
03/18/22 06:47 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Re: What's your go-to rust inhibitor? [Re: Moparite] #3026557
03/22/22 09:11 PM
03/22/22 09:11 PM
5thAve Offline
5thAve  Offline
For oil type stuff I use rust check. For paint I use tremclad aka rustoleum. Mainly because it's easy to get but also because it works.
Re: What's your go-to rust inhibitor? [Re: YGBSM] #3026651
03/23/22 07:08 AM
03/23/22 07:08 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
It is perhaps too expensive for widespread use
but
https://www.eezox.com/
is very impressive
Re: What's your go-to rust inhibitor? [Re: 360view] #3028519
03/28/22 10:09 PM
03/28/22 10:09 PM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
I use Chassis Saver.
I’m listening.
