trap rpm #3023769
03/13/22 10:02 PM
03/13/22 10:02 PM
westerly, ri. usa
440lebaron Offline OP
westerly, ri. usa
hi, whats a real would finish line rpm 1/4 mile, 4:56 29" 30" tire 727 stk ratio...? cars not running yet
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: trap rpm [Re: 440lebaron] #3023773
03/13/22 10:15 PM
03/13/22 10:15 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
How fast?
140MPH, 30" tire, 4.56 = about 7100 plus whatever converter slippage is. Few hundred on a decent one.
130 goes to 6600.
Re: trap rpm [Re: 440lebaron] #3023788
03/13/22 10:53 PM
03/13/22 10:53 PM
What size motor, how much HP and converter stall?
Re: trap rpm [Re: Cab_Burge] #3023814
03/14/22 01:17 AM
03/14/22 01:17 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I run 4.56ā€™s with a 30ā€ tire (PBR 29.5x10.5). Typically Iā€™m right at 120MPH. 727 with a 9-1/2ā€ converter. I see 6600 right at the stripe.
Re: trap rpm [Re: 440lebaron] #3023865
03/14/22 09:55 AM
03/14/22 09:55 AM
UK
rb446 Offline
rb446  Offline
UK
Impossible to know without knowing weight@the line and estimated fwhp and then you have verter slip to calculate in.
As an example, 600fwhp in a 3500@the line car with 4.56 with a 29" tyre and a good hook would look something like this>
60 Foot E.T. : 1.46 Seconds
1/8 Mile E.T. : 6.62 Seconds
1/8 Mile Trap Speed : 102.74 MPH
1/4 Mile E.T. : 10.49 Seconds
1/4 Mile Trap Speed : 128 MPH
1/4 Mile Trap RPM : 6,757 RPM+ 8% slip?=7297
with a 30" tyre
1/4 Mile Trap RPM : 6,532 RPM+8%=7054
so your looking on average around 250>300rpm difference from a 29>30" tyre across a wide range of hp/weight combo's.
And that works the same for our RR at 3800lbs with 4.10's and 675fwhp with 29's going to 30's, with an 11.39 SLR.
And similar for my old Cuda with 660fwhp@3300lbs with a 32" tyre and 4.88's and then with a 31" tyre around 260rpm more@the stripe.
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: trap rpm [Re: rb446] #3023889
03/14/22 10:52 AM
03/14/22 10:52 AM
westerly, ri. usa
westerly, ri. usa
est 500 hp 112/115 mph 4800 stall 4355 wgt
Re: trap rpm [Re: 440lebaron] #3023896
03/14/22 11:02 AM
03/14/22 11:02 AM
Northeast Indiana
73DAD Offline
73DAD  Offline
Northeast Indiana
With a hypothetically perfect torque converter with no slippage and no growth from the tires:
30" Tires
At 130 mph 6642rpm
At 120 mph 6131rpm
At 110 mph 5620rpm
29" Tires
At 130 mph 6871rpm
At 120 mph 6343rpm
At 110 mph 5813rpm
Re: trap rpm [Re: 440lebaron] #3023898
03/14/22 11:05 AM
03/14/22 11:05 AM
UK
rb446 Offline
rb446  Offline
UK
With a 29" tyre>
60 Foot E.T. : 1.67 Seconds
1/8 Mile E.T. : 7.56 Seconds
1/8 Mile Trap Speed : 89.89 MPH
1/4 Mile E.T. : 11.98 Seconds
1/4 Mile Trap Speed : 112 MPH
1/4 Mile Trap RPM : 5,912 RPM+8%slip=6348
30" tyre>
1/4 Mile Trap RPM : 5,715 RPM+8%slip=6172
Re: trap rpm [Re: 440lebaron] #3023921
03/14/22 12:03 PM
03/14/22 12:03 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
73 Duster - 3200lb ish race weight, stock stroke 360 running 11.70s with 4.56 gears, 8" 5000 stall converter 30" tire crosses at 6300, with 28" tire crossed close to 7K, I only did that once and said that was to much.
75 Duster - 3150lb ish race weight, stock stroke 440 running 10.70s with 4.56 gears 8" 5000 stall converter 30" tires crosses at 6700, 31" tire crossed at 63-6400.
Both cars are shifted at 6,000 and have stock 727 with just a Turbo Action Manual Valve body (Forward pattern).
Re: trap rpm [Re: DusterKid] #3023984
03/14/22 03:07 PM
03/14/22 03:07 PM
westerly, ri. usa
westerly, ri. usa
looks good did not want t be buzzing the motor at 7000
